Trailer build up is finally under way ( pics)
Discussion in 'Tow Rigs and Trailers' started by BRUISER, Mar 28, 2005.
  1. Wolfpack OffRoad
    Wolfpack OffRoad New Member
    Mar 21, 2005
    Trinity
    I think* he means the ends of the boards, so they do not all terminate at the same place.
  2. BRUISER
    BRUISER silent.. but deadly Moderator
    Mar 17, 2005
    Raleigh
    If correct ... WHY?
    I do not see the big deal???
    If you look at this pic you can see I doubled up the center.. so the end of each board is attached to its own support
    [​IMG]
  3. rockcity
    rockcity everyday is a chance to get better
    Apr 10, 2005
    Greenville, NC
    Yeah, stagger like on a deck. Its no big deal, just for looks mainly. Sometimes it helps to distribute the load a little, depending on your supports under the wood.
    Its just how I do mine and how I've seen many other trailers done.
    mainly personal preference, like painting it black or red or whatever color you want.
    Rob
  4. junkman
    junkman Active Member
    Mar 21, 2005
    roxboro
    If you go back to post #25 and #37 you will see a weak spot in his trailor. The gap where the angle from the tongue stops and the channel under the axles stop. the angle is not suported there and that is where it could fail.
  5. BRUISER
    Mar 17, 2005
    Raleigh
    Well I must admit I was very nervous to build a car hauler that will carry my Jeep and cars around on.. because I hear so many things about strenght.. etc... but after building this one and paying a lot more attention to trailers used everyday.. I am 100% satisfied with my work and I do nto see any problems areas with it at all.. sure there is always things that I would have done different, etc... but you can only learn by trying...
    So thanks everyone for all your input but I will take my home built any day over some of the ones I have seen on the road and at trail heads :)
  6. BRUISER
    Mar 17, 2005
    Raleigh
    oh and almost last update:
    Everything is done except I need to attach safety chains....
    So plan is to role it out Sunday :)
  7. BRUISER
    Mar 17, 2005
    Raleigh
    Well it is finally done and sitting at my house :)
    [​IMG]
    [​IMG]
    [​IMG]
    Specs:
    16' Deck
    82" wide
    2"x10" wood deck
    2- 6000lb axles
    brakes
    LED lights
    10,000lb rated tongue, and ball/receiver
    15" wheels
    7000lb Jack
  8. yager
    yager Better Faster Stronger
    Mar 17, 2005
    N. Raleigh, NC
    looks good ! Any plans for fenders?
    Where did you get the axles from ? Im still planning to stretch my trailer some and need some extra capacity for the camper..
  9. BRUISER
    Mar 17, 2005
    Raleigh
    ya I am gonna add fenders later (well if it will pass inspection tomorrow without them)
    I just have not decided yet how I want them..
    I got my axles froma local place (whata mess that was) I will tell ya later..
  10. hobie
    hobie Sub-par Moderator
    Mar 11, 2005
    Raleigh, NC
    Get a pic with Bruiser up on there...
    Glad you got it outta the garage.
    J
  11. junkman
    Mar 21, 2005
    roxboro
    Is it me or does that trailor already look like it is bowed down. I hate to keep making bad comments on it but an unsafe trailor can get someone hurt.
  12. Rich
    Rich Asshole at large
    Mar 17, 2005
    Central PA
    It actually looks bowed in the center up, which is fine IMO, since weight will help to level it out. - Kinda like the flatbed semi trailers
    Besides, a little bow by itself doesn't make it unsafe.
  13. thecarman
    thecarman Well-Known Member
    Mar 17, 2005
    Apex, NC
    I think that theory will work if the load was put at the peak of the bow, compressing it. But won't the wheels of a vehicle sit at then low points of the bow, making it bow more?
  14. Rob
    Rob Administrator Administrator
    Mar 11, 2005
    Sanford, NC
    I don't think his XJ weighs enough to bend it, I just looked at that trailer and it's stout. My only concern is that the tires look real close to the trailer, like about 1". But it's probably not an issue.
  15. BRUISER
    Mar 17, 2005
    Raleigh
    Bad News.
    Trailer brakes kept locking up when i was stopping and i can not figure out brake controller so i disconnected the wiring from truck and tied it around trailer and on way to work it fell down and dragged on ground so plug is half gone .. now i need to re wire it :(
    I'll be damned
  16. BRUISER
    Mar 17, 2005
    Raleigh
    as for bow in trailer, yes it does have bow...
    Reason: when i built trailer I made outside perfect square then I raised it off ground to make it easier to weld.. then i cut cross braces and layed them onto steel left over night came back and welded all cross bracers in.. well guess what I welded in the bow OOPS...
    but as stated by Rob i honestly do nto think it wil cause any problems and neither does DMV. as it is licensed and registered already.. trailer passed with flying colors.. and yes he really did inspect it (i took it to DMV office to get it inspected)
    He gave me lots of praise and said he has not see a homebrew this nice in many years :)
    So yes it has a bow and yes i wil still tow with it that is if i can figure outt his damn brake controller...
  17. Rich
    Mar 17, 2005
    Central PA
    You're right... absolutely right. Brain fart.
  18. BRUISER
    Mar 17, 2005
    Raleigh
    The hardest thing about this build was getting it out of shop yesterday by myself :)
    I could not get any help when I wanted help so I got impatient and did it myself....
    SOme day I will learn to wait
  19. RufusTheRam
    RufusTheRam New Member
    Mar 21, 2005
    Raleigh
    looks good! don't want to ask you to share an exact price, but did you save money vs. buying a pre built one? how many hours would you say you have in it?
  20. BRUISER
    Mar 17, 2005
    Raleigh
    I have no problem...
    Steel = FREE
    wood = $140
    bolts = $25
    tires = FREE
    Wheels = FREE
    Axles, leafs, brakes, u-bolts, etc = $ 550
    Jack = $ 50
    Tongue = $ 40
    Receiver = $ 20
    4 D-ring tie down = $ 20
    fenders = $ 40
    stickers = $15
    brake away box = $40
    trailer wiring = $40
    safety Chains = FREE
    Labor of hrs = 60 is my estimate
    so supplies cost = $ 975
    Labor cost = $ this depends on what you think your labor is worth
    As for me I learned so much doing this and I really like saying YES I built it that it was well worth it to me :)
  21. BUCKETOBOLTS
    BUCKETOBOLTS Member
    May 4, 2005
    Faith, NC
    I think you did a great job. How much do you think you'd have in it if you'd have had to buy the steel?
  22. BRUISER
    Mar 17, 2005
    Raleigh
    Thanks
    Not sure.. but if you wanted to find out call a steel place and ask them what 4x4 angle 1/4" thick cost for a 20' stick then multiply by 6. and there is yoiur answer for the amount of steel used
  23. BRUISER
    Mar 17, 2005
    Raleigh
    Well towed jeep around town last night and trailer towed great.. :)
    so I will find out how it really is tomorrow when I hit the road
  24. BoltOnJohn
    BoltOnJohn Well-Known Member
    Mar 21, 2005
    Franklinton, NC
    Congratulations dude! Looks good.
    I'm surprised your total was that high with free steel. Shows why trailers cost what they do because I know you're a frugal guy.
  25. BRUISER
    Mar 17, 2005
    Raleigh
    Well took the truck and trailer up to Tellico and it towed great..
    Truck could use a littl emore power but otherwise no problems :)
Share This Page
