Jeffncs
- Apr 4, 2017
- Wake Forest
I just picked up a 16+2 trailer. Love it but now want to make it mine with some mods / improvements.
Stop Bar
I’m looking to add a stop bar to the front of the deck. Is there an ideal height and width? I have some 3” channel to use for the vertical supports. I’ll have to buy material for the cross bar. Should that be tube or just use more 3” channel?
Trailer box
Im debating building a waterproof, surface mount (recessed into the deck) box or just keeping it simple with a tongue box. The recessed box would be slick, but a pain to make. The tongue box is quick and easy. The tongue box also offers a nice spot for the winch battery that is close to the wiring for a charging lead.
Winch
Im going to weld a 3/16” plate to the front cross bar at the deck surface and add a 4500# winch.
D-rings
Im adding a bunch on 1/2” d-rings along the sides and front of the trailer.
Backup light
I added a LED light bar under my previous trailer and I plan to do that again. Sucky part is that they cut the reverse light wire at the factory, so this mod may wait since I’ll likely have to redo (and better protect) the wiring. (Why do trailer manufacturers build stout trailers then have cruddy wiring?!?! I guess that’s a hidden corner to cut.
Anything else I need / should do?
Stop Bar
Trailer box
Winch
D-rings
Backup light
