Un-Brodozing an 05 TJ
Hot damn! Those are sexxxaay!
I blame @tobaccoroad4wd since the wife saw the same pattern on his seats and had to have them. 🤣 now I need a set with a little twist for the YJ. These things blow my Corbeaus away in comfort.
Spent a week one night at the Star Light in Jellico.
Oooooof.
There once was a moist county in Harlan KY…
That cabin wasn’t what it appeared.
There was a young lady destined for the meth pipe that hadn’t found it yet …that caught the eye of several Off roaders.
I put the same seats in my LJ, but mine aren’t quite so bougie. :laughing: Damn comfortable though.
I wasn’t sure if regular jackstands would hold the weight of a HP 30.
I’ll tear this one down for a refresh and have it mostly ready to go once the LP leaves the chat. I’m amazed it’s held up to what’s been thrown at it so far but the Zillas might just send it to Jesus.
Tubes are cleaned off and the upper bushing pressed out of the housing on the HP30. This next part will surely accelerate the need to finish that axle. Have a Barnes truss and C gussets on the table for it. Just need to scoop up some fresh ball joints and unit bearings for it. Then it will be ready for whatever is left out of the existing axle when Alex grenades the LP.
Headed to the ranch again in October so we finally settled on some beadlocks for the poverty stickies. I would have liked to do a set of weld on’s with some 15x6 trailer wheels but time is money. Ended up with some 15x8 Raceline/Allied steelies and did the Gorilla Tape inner bead mod. 15” beadlocks aren’t as common as they used to be for sure.
First trip on the poverty Treps was a success. Nothing let go but where the old tires slipped a little, the extra traction makes the need for deeper gearing more noticeable. Needs a bushing in the shift linkage, bolt check and I’ve got a new Trektop sitting in the shop so we can drive it around more this winter.
If I can come across a reasonably priced Rubi case we might go that route. If not, a Rubicrawler kit would work.
Finally got warm enough to throw the new Trektop on.
Last trip out the shift linkage came apart again like it did on me a few years ago. BushingFix has a pretty straightforward replacement so that got addressed. Parking brake needed adjusting since the new cables seem to have stretched. Otherwise this thing should be ready for the ranch later in the month.
Replaced the brake master cylinder after some issues at the ranch. Flushed all the fluid, gave it a bolt check and put the MT’s back on for the road. Burned some miles running around this weekend turkey hunting and running to town vs driving the diesel.
I definitely forgot that I had bumped the OPDA a while back and this thing was throwing a P0016 code. Admittedly I left it alone when it happened because it brings the rev limiter down to 3500rpm when it’s out of sync. A valet mode of sorts for a new driver who has a heavy foot when you say “bump it” 😂 guess I’ll fix that this weekend.
Waiting on the yokes and shifter parts for the Rubi case which should all be here next week and had some time to kill.
I finally finished tearing down the HP30. Tacked everything up on the truss, got it tacked to the axle and then heated up the center section, burned it in and wrapped it up to cool. Once the truss is done I’ll do the C gussets the same way.
Shooting to have the Rubi case in for the Veterans ride to use it as a shakedown before our new years trip. We will see if the 9-5 and 5-9 cooperate.
241 ready to go in hopefully over the weekend. Need a rain day.
Changed out the front and rear yokes to 1310 rather than using conversion joints up front and having to change the case end of the rear shaft. Savvy shifter parts are here too. The only difference is the end that attaches to the lever on the trans and the bracket that holds it.
Pulled the Jeep in the shop last night after work and farm chore’n. Got the cases swapped out. All that was left this morning was to top off the fluid and go for a test drive.
Out with the 231
In with the 241
Test drive complete. Once nothing flew off the rig at road speed and some hills around the farm were climbed in low range, back in the shop it went.
For a while I’ve had no speedo, odometer hasn’t been working, CEL was being thrown for cam sensor position and the “no fuse” alert was on the dash. With the new case that fixed the speedometer and odometer issue, still needs to be calibrated for tires and gears, maybe, if I feel like it. I cleared the codes, reset the OPDA and cam sensor and so far no codes or limp mode after another test drive. The “no fuse” was related to a blown fuse in the under hood box on the circuit that controls the dome lights. Don’t really care about dome lights but it’s nice to not have a Christmas tree on the dash now.
Going to throw this thing on the trailer and head down to support our people at the Veterans Ride at URE next weekend.
Uwharrie shakedown was a success. @SPOA87YJ and I made a good hotlap and ran pretty much everything except Dutch John. Rubi case was a game changer. Wash, bolt check and we should be ready for new years at the ranch.
