New everything better than oem 4 bolt mains and aluminum heads, hard to beat the value from blueprint especially the package dealsYeah, they got one package that comes with the Holly sniper and HEI dizzy. Should be a massive change when comparing dyno charts, the stock engine the HP and TQ don't even meet until over 5k which is well past value float.
Not that it is "safe" but my front down bars a welded to the boat sides which are bolted to the body mounts and body.Cage bolted down with new non torx headed hardware. Need to bolt down the stanchions in the front but needs to tie in to something more substantial than the floor pans. May try to cobble up a plate that comes of my Warn sliders. The other jeep had rectangle tube to the frame and one bolt through it but you can see if from the side and it looks like an outrigger for a slide in camper to me.
Got the other jeep loosely assembled, radiator hooked up, transmissioin lines reconnected and tossed a battery in to see what would happen. Surprised me when it started....I bought it thinking it was non runner. Showing 4 codes for O2 sensor and threw one for cps (i think)....hit a 2k rev limit. Its an '05 and from what ive been reading prone to have bad pcm and opda. Ran good enough to hoon it down the road though..
You didn’t spill any fluids, you just rusproofed your front end
Yikes! Low fluid cause that damage?Replaced the busted T-case in the tow rig. Went ahead and changed the diff fluid and put on new covers.
Not really sure. My son was driving it when it exploded. There was fluid everywhere so it wasn’t empty.Yikes! Low fluid cause that damage?
4wd rooster tails hell yeah brotherNot really sure. My son was driving it when it exploded. There was fluid everywhere so it wasn’t empty.
I should have added. On 77 northbound doing about 70. T-case is obviously gone, front driveshaft is gone, and bent the front sway bar links.4wd rooster tails hell yeah brother
What kind of truck? I might can locate you oneI should have added. On 77 northbound doing about 70. T-case is obviously gone, front driveshaft is gone, and bent the front sway bar links.
Go the t-case in, on the look out for a driveshaft now, have the sway bar links on order.
It's a 2003 ford excursion. Not sure if a superduty is the same.What kind of truck? I might can locate you one
I remember my old 35.Got the fo-tay-fo rear swap started yesterday. Just had to get brake line and ebrake today and slide it out. Ill move the blue top garage over tomorrow evening and hopefully loosen a few bolts on the turdy five.
Freaking water pump is leaking out the weep hole already and I don’t even have 100 miles on it
Edit: of course
Got my '56 back on the road today! He ain't perfect but he'll do...
View attachment 460434View attachment 460435View attachment 460436View attachment 460437
