Jeeper Preacher
New Member
- Jan 29, 2007
- Fuquay-Varina
Where would you suggest to get some media blasting done in or around Wake County? Looking for frame blasting and tub blasting. Thanks.
not sure where wake county is, but i'm going to be glass bead blasting my yj frame and tub in the near future. i'll be doing it at my shop in Clover, sc. let me know if your interested and i can do both at same time.
Make your own blaster and do it yourself!
I built one from an 11 gal air tank from home depot You can get the gun from there also. Mine works awesome.I welded a
1 1/2 inch coupling to the top of the tank with a 1 1/2 plug to add sand. I'll add an actual photo later. and using an actual air tank that is rated for 200psi i didnt add the blow off valve cause my compressor only goes to 125psi.
