I've never had a single one come loose. How do you tighten em? (hint: "using my fingers" is NOT the right answerAnyone had a problem losing bar nuts on a sthil? Often? Yes it gets cleaned.
How old are yalls saws? My 30 year old nuts work just fine and have yet to fall off![]()
Interesting. Putting better antivibe on the saw would further isolate the mass of the handle and probably fuel tank, basically lightening the mass of the vibrating member (that's what she said). But I would not think it would be enough to matter since even the old saws had springs. Also, the nuts are captive and loaded, so a slight change in frequency or amplitude really shouldn't make a difference. I'd guess the parts are now cheaper material. Is your side cover aluminum or plastic? Do the studs have anyou play in them when freestanding?Mine is new ...bought when I started this thread. I've since picked up an older saw and it has no issue. the vibe dampening seems to transmit the vibes to the case
mine had play on the bar studs , I stuck a piece of 3/32nd tig wire in there to take up the slack and that fixed my problems with the bar coming looseInteresting. Putting better antivibe on the saw would further isolate the mass of the handle and probably fuel tank, basically lightening the mass of the vibrating member (that's what she said). But I would not think it would be enough to matter since even the old saws had springs. Also, the nuts are captive and loaded, so a slight change in frequency or amplitude really shouldn't make a difference. I'd guess the parts are now cheaper material. Is your side cover aluminum or plastic? Do the studs have anyou play in them when freestanding?
But now you don't have to hire a stumpgrinder, and you can fill it with sand to give the kids a stealth sandbox!Oh, I was going to chop and drop, but the fucker fell over.
My saw is a 1976 Stihl , my grandfather traded a car for it in 76 , he's 87 so he doesn't need to use it , gave it to me , did a carb rebiuld and its going strong . It will make a man out of you , no vibration damping , no chain brake , weighs almost 20 pounds , over 20 lbs with the bow on it , uses a .404 chain. View attachment 230420 View attachment 230421
As of today, I have at least ten stumps that need ground. So that's not really changing the calculation.![]()
You need a mini excavator.As of today, I have at least ten stumps that need ground. So that's not really changing the calculation.![]()
That or using the fire or sugar tricks and wait them out.
Please elaborate. Is that cheaper than renting a stump grinder?
I have a 21" bar on it , the purpose of the bow , is how they logged back in the day , a guy with a regular saw would drop the tree , then the guy with the bow saw would limb it and cut it to length , the bow works great for trees already on the ground , you dont have to bend over , just lay the saw on the limb and let its own weight cut through the branch .What size bar do you have on that?
I just picked up an 041. Was looking for an 044/046 but got this for a song.
Also, what have you used the bow for? Ive seen them, and they look cool, but i cant understand the purpose.
