Towing with a truck camper?
BigClay
Knower of useless ZJ things
Winston-Salem
Have any of you ever used a hitch extension to tow a jeep on a trailer behind truck with a slide in camper? Looking for experiences and opinions.
This is what I am referring to
I'm not sure I'd be comfortable with that on anything other than a class V hitch
It's a package deal. Buy the special hitch for the truck, then buy the extension length that you need to match your camper, then get a WD hitch for the trailer.
Then put air bags on the truck. :D
The super hitch is beef bit they discontinued them on 1500 trucks for a reason need a hd truck for sure
Seems like a bad idea to me, but I don't know all the specifics. With one of the new 3" receivers it might make more sense, but with a 2", you're really pushing the limits of the strength of that tube. And that's assuming the hitch frame mounting is up to par.
Quoted for truth....
I just would only get an 8ft, It's what I'm planning to do. Not a big fan of the extensions.
Can't find many 8ft with a bathroom, and that is the new requirement for the girls :D
The one I was looking at is for a 2.5" class V hitch if that may make a difference.
It's generally two 2" receivers, one over top the other, or a 2" and a 2.5".
The leverage that those extensions put on your receiver reduces the capacity greatly, they are great for lighter loads. For example, boats etc.. I wouldn't recommend them for the heavier tongue weight of towing a vehicle. I ended up going with a bigger hitch with a longer shank like this one. It worked well for my situation but every camper is different. I just removed the back jacks (3 bolts each side) every time I pulled a trailer. Worked great!
Curt Multi-Ball Adjustable Ball Mount for 2" Trailer Hitches Curt Ball Mounts D900
Better angle
Current set up on a gooseneck
If you are still looking for a camper I could sell you this one
09' Starcraft, 8'2" long, full wet bath, 3 way fridge, king size bed, 3 burner stove, out door shower and speakers. A/c and heat, hot water heater.
Being that your long bed clay that'll fit and you won't need an extension for the hitch.
Find a camper that doesn't need a hitch receiver and I'd highly recommend pulling it with a dually. Here's my setup, trailer tongue goes under the camper with plenty of room.
Clay there are plenty of truck campers with bathrooms that won't be longer than 8 feet. However, I am also a fan of removing the rear Jacks as my camper is 8 feet long on a 6.5 bed.
Are removing the rear jacks just to clear the trailer?
Looked for a long time to find one that that would work with my setup without using an extension. No bathroom in ours but budget wasn’t there anyway.
We decided to remodel the interior and are excited to start using it. Pay attention to jack placement as others have mentioned for your truck/trailer set up.
View attachment 257952 View attachment 257953
Nice setup
My brother has built a new frame for an 8’ slide in. He has another one that he is using for the parts. I think he will part with both if you want a project to make how ever you want. Let me know and I’ll get you some pics.
