obullfish
Carolina Trail Blazers
- Nov 21, 2011
- Candler N.C.
Dude come on. You beat me to some good seats.
When you going to swap that tan interior for a black one? Lots of opportunity there to get a lot blacker.
They look great in there!
It has two sweaters?!
With some good advice from @BUCKEYE PERFORMANCE INC. and @Jason W. I figured out a major squeak/ squeal in my driveline. Driving it sounded like a pinion bearing to me so I got it up in the air and let it run in gear while I was up under it listening for where the noise was coming from. Pinpointed the noise to either the output of the Tcase or driveshaft. Pulled the driveshaft and found that the ball in the double cardigan joint was the culprit. With some good advice from Chris I rounded up a needle for the grease gun and found a needle grease port on the driveshaft and put 8-10 pumps of grease into it. I assume that the only grease this has ever had was when it was new. Going to put a few miles on it and put some more grease into the port and call it good.
Yeah, I figured it wouldn't be TOO bad. The only thing would possibly be crankcase pressure blowing it out. I took the other bolts out this morning and it does NOT want to come off anyway. I may run it at least the 500 miles until I change the oil due to the new camshaft and see what happens.@RubiconBear my .02 would be to run it. If it were a WP bolt I’d reconsider but down on the corner of the timingcovwr I don’t see why it would be a huge issue at all.
I'm too broke/cheap to buy a long spline front driveshaft, so I started making a new PTO front shaft.
Did some lathe work last week and started welding it up tonight
View attachment 258484 View attachment 258485
Not sure where you can get it. A buddy of mine knows the owner of a local produce company and I got it out of their scrap.Where did you get that style pto shaft
I remember seeing that rig either on here or Craigslist. Can’t remember, but I thought it had potential with a little work. Cleans up nicely.Traded for this 81 CJ5 several weeks ago. Slowly getting it back trail ready after a couple years sitting outside being neglected.
Loaded up heading to its new home View attachment 259003
After a little pressure washing View attachment 259002
Replacing leaking valve cover gasket.
Replaced frozen rear brake calipers
View attachment 259026 Sanding and painting...hoping it’s in for Saturday
