RubiconBear
- May 31, 2012
Well, last night I found out the noise in my rear D44 is the 2 small spider gears missing some little chunks. The larger ones are fine. Do I need to replace all 4 of can I just do the like ones? I'm assuming all 4. Any brand in particular, or does it matter. I don't want something so cheap they break again in a few thousand miles.
Also, every site I've looked at shows a cross pin bolt or roll pin for the D44 with trac lok. It looks like mine had a roll pin, but not 100% sure. Here's a pic, I'll try and get another if y'all need it.
If it's a roll pin, I should be able to punch it out without removing the carrier, right? If it's a bolt, it's obviously broken. Are the Yukon or Nitro Gear removal kits good, or is there a better way I couldn't find?
Lastly, when I rotate one wheel, the other spins the same direction, as it should with the LS. It didn't make any weird sounds, other than the spider gears. Do I need to worry about getting new clutch packs, too? Thanks in advance.
Sent from my LM-G710VM using Tapatalk
