Jeff B
Thanos was right
- Dec 23, 2006
- Lincolnton N.C.
You can run straight co2, but you won't like it unless you're running flux core..
Straight co2 and hard wire is globular, spattery, really kind of wasteful. However it digs deeper then 75/25
75/25 with hard wire (mig) is the industry standard. Low spatter and good penetration. Cools fast for out of position work.
85/15. Is almost a spray arc, higher voltages and larger wire diameter .45.
Stick with 75/25, you will waste coin with anything else in the mig welding area.
