palmetto zuk
Well hung member
- May 22, 2017
- Rock Hill (Da Hill City)
i check everytime i go. That was just good luck i guess.damn, what a score on that rear. they got any more?
yeah i did. I have a few SR5 clusters i bought when i got the inclometer. I bought it in a group of parts for like 125bucks. The cluster swap is easy. You have to source a oil pressure sending unit from one with a guage. The plug is the same. Bought mine used on ebay for like 11 bucks cause i think they are 60 bucks on rock auto.Got the same damn rig...subscribed.
Did you swap out the cluster for one w/ a tach and put that fancy inclinometer in there?
After christmas we need to get shit together.So does this mean I need to clean up my shop so we can start working again? Its about time to hang the body on my jeep and finish up your e locker
I bet yours does go! Before putting mine under the knife about 10 months ago it was bone stock w/ 31x10.50s. I ran all over URE except the ledge side of Daniel w/ little to no issues whatsoever. The only knock I have on the stock suspension is it's stiff and doesn't flex too well. I've been pretty pleased w/ my setup as is so far but I've got an issue w/ my pitman arm hitting high steer right now. Steering box got moved as far forward as it would go and the angle it is mounted won't let me run a flat pitman arm (it'll hit the frame) so I've got to figure that out. I'm hoping if I redo the RUF pack a little to get a bit more lift (making the lower leafs a bit longer so it doesn't settle so much) that it'll help but I guess we'll see. I've got TG 5" springs but I thought it sat up too damn high w/ those and I like the approach angle w/ the RUF by moving the axle even further forward.yeah i did. I have a few SR5 clusters i bought when i got the inclometer. I bought it in a group of parts for like 125bucks. The cluster swap is easy. You have to source a oil pressure sending unit from one with a guage. The plug is the same. Bought mine used on ebay for like 11 bucks cause i think they are 60 bucks on rock auto.
Go get some 35s and some spacers ill bring the beer and we can make them fit.
Edit: just saw in your sig you have ruf and 63s already lol. Its funny i can follow rigs with that setup anywhere its just a harsher ride and sometimes its a little more sketchy but sometimes with me being lower i have less trouble. When you wanna go wheelin?
The incolmeter is cool as fvck IMO
. And I'd be down to go wheeling sometime when you want man...just give me a heads up.absolutely ill get you a cluster not gonna rape you on it i dont need 3 of them. I have some bastard RUF packs at the house if you wanna take them and give them a try. The set i got from @ProbablyBroke might help you out if you need them you are welcome to give them a shot.I bet yours does go! Before putting mine under the knife about 10 months ago it was bone stock w/ 31x10.50s. I ran all over URE except the ledge side of Daniel w/ little to no issues whatsoever. The only knock I have on the stock suspension is it's stiff and doesn't flex too well. I've been pretty pleased w/ my setup as is so far but I've got an issue w/ my pitman arm hitting high steer right now. Steering box got moved as far forward as it would go and the angle it is mounted won't let me run a flat pitman arm (it'll hit the frame) so I've got to figure that out. I'm hoping if I redo the RUF pack a little to get a bit more lift (making the lower leafs a bit longer so it doesn't settle so much) that it'll help but I guess we'll see. I've got TG 5" springs but I thought it sat up too damn high w/ those and I like the approach angle w/ the RUF by moving the axle even further forward.
But hell yea, I like the tach and inclinometer for sure! I'll likely be doing the same as soon as I can source both...hopefully I can find a deal like what you got. Lmk if you want to get rid of one of those extra clusters you've got if they're taking up space...be glad to take one off your hands. And I'd be down to go wheeling sometime when you want man...just give me a heads up.
Sounds good to me. I'm around all next week. If you're going to be around I can slide down to your neck of the woods. I'm on the NW side of CLT so shouldn't be too far of a drive at all.absolutely ill get you a cluster not gonna rape you on it i dont need 3 of them. I have some bastard RUF packs at the house if you wanna take them and give them a try. The set i got from @ProbablyBroke might help you out if you need them you are welcome to give them a shot.
I’ll be in Ohio till Wednesday but the rest of the week I’m free I’ll let you know.Sounds good to me. I'm around all next week. If you're going to be around I can slide down to your neck of the woods. I'm on the NW side of CLT so shouldn't be too far of a drive at all.
So i thought id post some pics and shit from the weekend. Had a great weekend at Gulches with @Dirt Mcgert and @scbronco
The #pushpullsteering is still holding in there strong. Still no real failures. Not sure how i have not popped a birf yet but im not complaining.
and some bonus of me working.
Lets do it. Im always up for a trip to go see Skip.I need to get to Gulches this year.
