If the front rides well, don't change springs for flex. Add a rear swaybar if you want to force the front to work more.rear flexes great, may need to soften the front to get a little more flex out of it.![]()
good point, I probably could use a rear sway bar at the leastIf the front rides well, don't change springs for flex. Add a rear swaybar if you want to force the front to work more.
Decided to make it street legal thanks to the relaxed laws in SC compared to other states. All I had to do was one phone call to put insurance on it, run the title to the county treasury office ($19 vehicle tax lol) then swing by the dmv on my way home and got a tag. Only the insurance company asked for a picture of the vehicle to put it on file.
As far as wheels and tires go, I did not want to damage my reds while driving down the road, nor did I want to unmount them off of the beadlocks. So thanks to the for sale section on here, I got a really good deal on a set of rims with the correct 8-170 bolt pattern, and a set of 39.5 Iroks.
The rims had a second valve stem hole drilled for running an internal beadlock. So I drilled and tapped it for a 1/8 NPT plug that I can remove with the tire still mounted. I used this to add antifreeze to the tires to balance them. I put about a quart in each tire and it seems to work great!
Once I finish repairing my tcase and making sure my rear driveshaft doesn't fall out again.so when are you driving it down to the shop and going on a road trip with me and Joe?
Cool. if we can get our co-worker Jeff to hurry up and finish his that'll be four 1 ton Jeeps out terrorizing the streets.Once I finish repairing my tcase and making sure my rear driveshaft doesn't fall out again.
After this weekends wheeling trip to river rock, I probably should start looking for a 42in sticky. The sterling 10.5 hangs low and catches everything. But besides smashing my diff on every rock, the jeep did great!
