- Mar 20, 2005
- Hendersonville, NC
Thanks, I know how it works. Troublesome that it quieted down after I was screwing with it. Still hasn't come back and we did about 15 miles in it. I feel pretty confident it's the injector.. I've been through every push rod length, measured the seat height for each roller rocker. measured the spring compression verses the rocker ratio. Had the head checked by the machinist when I went through it the second time. Spring pressures are exact and new stems and stem height was checked also. I was beginning to think it was because of the aggressive cam, but it's only that 1 cylinder.
I'll be pulling the harness loom and do an inspection there and measure the voltages against the other cylinders sat. morning.
I know you're no dummy and paused like 3 times writing that post.
But it was just gas from supper
