iwaxmyjimmy
College Web Wheeler
- Mar 10, 2007
- Greenville NC
Can we all at least agree it’s not a hot water heater.... it’s just a water heater?
The hour rating is just an arbitrary number that is based on flow rate, Delta T, and acceptable temp drop. It has everything to do with flow rate, they just made it into a simple number so architects can understand it.With a tank system, you can calculate how much hot water the tank can provide at a specific temperature delta for the first hour. If you exceed that capacity, you run out of hot water. It doesn't matter what the flow rate is, once it's gone it's gone.
Relative to a tankless system, it conserves energy, especially for smaller consumption needs. Heating a gallon of water to cook a pot of noodles will require a tankless system to heat a gallon of water from cold to full hot at 40 amps or whatever for 30 seconds or more. With a tank system using a gallon of hot may not even bring on the elements in a 50 gallon tank. Theoretically, the energy required to heat a gallon of water should be equal in the overall scheme of things, but the tankless never conserves the water it has heated, whereas a tank system does.The thermal buffer doesn't conserve energy though, it just stores energy. It still takes a specific amount of thermal energy to change the temp of water, regardless of how fast you do it. You're not saving energy by heating the water at a lower rate with a smaller heater on a tanked unit.
Dishwashers often make their own hot water, just have a single tap of cold off of the sink supply.I’m going to take a cold shower after a few loads of laundry, the dishwasher has run, the two girls get a bath and the wife takes a bath in the jacuzzi tub....
Actually, it's "Domestic Water Heater"... to differentiate it from other types
I've seen several mentions of laundry being part of the issue too. I find this interesting... we only use hot water for a small percent of our laundry. Modern detergents do a fine job w/ cold.
We avoid running those things at the same time as the shower just to avoid poor pressure.
Yeah, the gas tank isn't leaking. A tankless heater is like a leaking gas tank, overfilling and leaking out a little every time. If you're hung up on my usage of the term "conserve" then assume it's adiabatic.Nothing is conserved. The tanked unit has already heated the water to get the entire tank to temperature setpoint, so the energy has already been used. The tankless unit just uses the energy at time of use. When you use the energy to heat the water does not change the amount of energy needed to heat the water.
What you're saying is this: You go on a trip. You start with a full tank of gas. The trip was short and you didn't have to fill up during the trip, and because you didn't have to fill up your car hasn't consumed any gas.
Is there something not-quite-right there?![]()
Either some of you bastards lose every battle with your spouse and have to "make up your manhood and regain self righteousness and sense of worth" here, or you're the same "has to have the last word even if you're wrong" asshole self to your spouse. Either way, God help her![]()
how do you know my wife?I've seen several mentions of laundry being part of the issue too. I find this interesting... we only use hot water for a small percent of our laundry. Modern detergents do a fine job w/ cold.
Cold water laundry is about half the reason we have a bed bug infestation in this country. That, and nobody does a spring cleaning down to the baseboards every year.
1 - I don't have bed bugs so that's not a worry here ;-)Cold water laundry is about half the reason we have a bed bug infestation in this country. That, and nobody does a spring cleaning down to the baseboards every year.
I replaced mine late last summer. The WH is about 4 years old, rated as a 7 year model. I was doing some other work on it and it occurred to me I hadn't checked it since I installed it.About the Anode rod. Who Has changed one, & How? I've know about them for years, but when I looked into changing one, it became Unrealistic!. I found the hole, listed in the parts manual. Opened it & worked for a while trying to dig the insulation/foam out of it. Finally said Frick it! Few years later, it rusted out the bottom. I yanked the tank out, & Completely stripped the outer metal skin. More fricking Foam around it than insulation blanket. When I got to the rod, I couldn't break it loose. Guess it was rusted in. Never messed with another.
Yes! If I remember right, there was 1 1/2 - 2 " of sprayed foam, on top & sides of tank. Try digging through that. Then the Rod was countersunk. I' thinking the access hole, wasn't large enough to get a socket through. It was a Bastard. I may check the one I have now, but it's only a year old. Last unit lasted about 7 1/2 years, with a 8 yr. warranty. A O Smith, which covers Lowe's now, replaced it free of charge! Nothing was ever said or asked about the rod or maintenance.I replaced mine late last summer. The WH is about 4 years old, rated as a 7 year model. I was doing some other work on it and it occurred to me I hadn't checked it since I installed it.
It was pretty stuck (from rust), but came out - took a giant ass socket, like a 27mm or something. That rod was almost completely gone, like down to a tiny rusted sliver. No way the WH would have lasted another year at that rate.
Other that being stuck, it shouldn't be that hard to get to - not sure why you'd have to remove any insulation? Usually they are mounted from the top. On mine (a GE) the bolt is counter sunk into a hole a little bit, so a socket is the only way to get it, but it's definitely accessible.
