mbalbritton
- Mar 22, 2005
- Orlando, FL
approx. 19' tall and made from about 200K LEGO bricks. The guy in the teal shirt stands about 6'2" and he's the one that built it in 650 hours. This one is going to LEGOLAND New York.
Anybody jumped off it yet?approx. 19' tall and made from about 200K LEGO bricks. The guy in the teal shirt stands about 6'2" and he's the one that built it in 650 hours. This one is going to LEGOLAND New York.
Hopefully some Democratic presidential candidates will.Anybody jumped off it yet?
Related - is there an internal structure that is not Lego? E.g. hidden structural beams etc?Question. Are the blocks bonded and glued permanently? I always hated dropping my creations as a kid...planting firecrackers in them was a different story.
Beware of the KragleQuestion. Are the blocks bonded and glued permanently? I always hated dropping my creations as a kid...planting firecrackers in them was a different story.
I just got more jealous of that whole process.....welding, machining, and building bricks. Talk about a phenomenal kid at heart place to be.We do use a solution to bind the bricks at the molecular level. But not allowed to talk about it. You can however use MEK to do the same. But you better act fast and not put he wrong part in the wrong place. It melts the ABS plastic together.
as for internal, the models are hollow with LEGO bracing. For models over 4’ we do have SS structures. For this it’s a 4x4 post running up the middle.
for sculptures like say a dragon or animal, there is a skeleton made of SS.
We do have a full machine shop here too. Certified welders, machinist, draftsman, electricians. For the models themselves ww design them in LEGO proprietary software. Basically a 3D CAD software that has all of the LEGO parts built into the program.
As well the builders go through some extensive training on build techniques to ensure it’s built strong and safe.
No crap.I just got more jealous of that whole process.....welding, machining, and building bricks. Talk about a phenomenal kid at heart place to be.
MEK is nasty stuff. I generally avoid it whenever possible.
Are you at liberty to say anything about the setup process to prepare for build? How to get organized etc?
Like, OK you have a CAD model. Then order 200,000 parts.... so now hundreds of thousands of parts show up. How does one organize that and prepare for a 4 months long build project with so many pieces, so you can find what you need at the right time? The logistics of this seem baffling to me.
Or, I assume the project must be broken into stages, with batches of parts coming as each one winds down. I guess it's like any other construction management project, just on a different scale.
I'm an idea guy. Not so good at planning stuff, lol.
Also, I'm assuming a build like this must be a team of constructors. Rough math says ~300 block per hour average, or ~50 clicks per minute, working straight w/o any coffee time, ass scracthing or moving a ladder around.
Absolutely, there are color variations from different batches of LEGO. But they will also UV Fade at different rates. It's crazy to see how brutal the Sun and weather is on this.If you're dealing with 200k or more blocks, do you have to worry about slight color variations due to different manufacturing lots, and mix lots as you assemble layers? Or are they mostly consistent?
Yes, if you look closely you'll see segments. We try to stick to sections no more than about 4' tall. For shipping, each section is palatalized, wrapped in cloth and strapped down and everything goes by dedicated truck and each pallet is screwed to the floor of the truck. Never LTL!!! that building is valued at about $30K.So how do you ship something like that? Does it come apart in sections that are not bonded, or does it stay in one piece?
Very cool, and I’m glad you shared it!
Nope. We do not use any brick that you can not buy from LEGO. Even when LEGO discontinues a part, we have to remove it from inventory.Do you ever have to get a factory to make a custom run of bricks to make something work out? Custom color, shape, length, etc??
at my discretion.are people allowed to take tours of your facility?
correct. Look up LEGO software call LEGO Brick Builder and LEGO Digital Designer. You too can design like the professionals!Now this wasnt a kit right? This guy actually designed it and built it just using blocks that he had to find and figure out correct?
