91samurai
- Apr 20, 2016
- Midland, Nc
This thread will be about getting my samurai ready for a trip to Harlan about a year from now. Me and my fiancé are planning a rock crawling trip for our honeymoon at the end of October 2020. Previous build info on my samurai is in my k10 build thread but I’m finally doing a thread just for it. I thought it was done before but I just keep wanting to cut it up and make it better. I decided to link it and lower it a few years ago and finished it a little over a year ago. It has been performing great, but trying to follow (or lead) rigs on 40s means I’m really pushing the limits of my little samurai on 31s
This is where I’m at now. Stock axles, Yukon spool and hardened crosspin in the rear and a spartan locker with trail gear highsteer in the front. Both axles are heavily shaved for ground clearance. 4:1 gears in the transfer case and a wore out 1.3 with a Toyota 250 carb. It’s stretched 10 inches with a 3 link front and 12 inch coilover springs.
I really enjoy the challenge of going places on 31s I have no business being. This has lead to several rollovers and being on a winch cable when things get tippy. The engine not having enough torque to pull me up stuff has meant more winching.
So the new upgrades will be wider axles, a 1.6 engine, and if I have time a flatbelly skidplate with a raised transfercase.
While planning the axle upgrades I was searching for a rear axle to match a Dana 30 front that’s been swapped to passenger drop. While trying to find a offset rear axle that would be the same width as a Dana 30 with good ground clearance I realized I should just put another Dana 30 in the rear and I would have rear steer. My dads Rockwell buggy had rear steer when I was a kid and think it is so cool. The steering will be locked out for now and I will add the ram after I know I like the extra width and don’t want to swap the samurai axles back in. I broke a front axle shaft in the samurai at uwharrie so I’m going to start the axle swap rather than fix the samurai axle.
I’m hoping that by posting this as I start the build up it will mean if I’m doing anything wrong it will be pointed out by some of the good fabricators here. I have already bought a low pinion Dana 30 housing with 4.10s to start measuring. Once I can piece the rest of the axle parts together I will be starting on the rear axle swap. I’m planning on running wheel adapters to be able to use my 5x5.5 beadlocks I already have
You know like inspect it by adding it to my insurance policy and stuff like that
