Last night a good friend of mine came over and we set out to diagnose and fix the clutch issue. I walked him through the math plus everything I have already checked: clutch, throwout bearing, slave etc. We decided to throw the transmission into the jeep. Got it all bolted down and lined up pretty easy. Amazing what having an extra set of hands and eyeballs will do with productivity.
Once we got the transmission installed, it was time to manually move the clutch fork. We installed the shifter and put it into first gear. I sandwiched a 2x4 in between the clutch fork and the bellhousing and used a pry bar to try and move it. No dice. I could feel the throwout bearing hitting the fingers but couldn't press it in enough to disengage the clutch and turn the output shaft on the transmission. We then took a ratchet strap and hooked to the clutch fork and antiwrap bar. Success!
. I'm so glad I don't have to buy an expensive adjustable throwout bearing or change out the fork. This proves my math was correct We were able to disengage the clutch and spin the output shaft while it was in first gear. There was a noticeable amount of clutch fork movement once we finally got it to engage. I guess it being a new clutch/pressure plate it obviously isn't broken in yet. We took a measurement on where the clutch fork needed to be to disengage the clutch and adjusted the slave down to work.
We then started bleeding the slave with it not attached per
@paradisePWoffrd (great suggestion BTW!). We did a variety of bleeds, we started with gravity bleed, then switched to a one man bleed, and then finished up by pumping the pedal. We were able to get full travel out of the slave(1 1/4") with a good firm clutch pedal. About the time that we were going to hook the slave up to the transmission, I noticed that I was only getting a half pedal press with a very hard stop in the pedal about halfway down. We figured that there was a air bubble still in the slave. So, bled it some more, got crystal clear fluid out no bubbles. I could pump the pedal 1 to 2 times with full pedal stroke and then it locked up halfway again. Repeat the bleed process, still the same. 1-2 full pedal strokes after bleeding and then a hard stop at 1/2 pedal(note that the slave was not hooked up to anything at this point)
The only thing that both of us came up with is a bad cup seal at this point. I bought the slave almost a year ago from Summit but obviously am just now hooking it up and using it. I cant think of anything else that it would be? I don't think my slave is rebuildable either. The reviews on Summit aren't great but I figured Wilwood makes good products so this should be a good one. I am going to call Summit today to see what they can do for me. It was only $80 but if I can return this one that would be great. Summit has always had really good customer service so we will see.
Other news, I got the transmission crossmember installed again and bolted down. It's a tight fit and requires a lot of prying to get all the bolts lined up. I have not installed the transfer case yet. I still want to add an oil sight tube to the D300. Also the extra space that I have with it out right now will allow me to finish welding the exhaust, add some exhaust hangers and get a better routing for my electrical wires. My battery will be in between the front seats and I have the battery cables running down the inside of the passenger framerail. I need to protect them from the exhaust heat and along with my friend and
@getstucksome suggestion, I'm probably going to run them down the outside of the frame rails tight to the body. Or I can run them through the old heater hose ports in the firewall on the the passenger side but I'm undecided if I like that route or not. I'll have to reconfigure some of the wires but it shouldn't be too terrible.
Edit: Summit racing customer service is kick ass. They warrantied it and will be sending me a new one at no cost with a box/return label for the bad one.
