ckruzer
Infidel
- Jul 2, 2015
- asheville nc
So much pipe (need to put up a Logan-Free Zone sign to keep away the Logan’s
Please don't back fill that as it is....
8000 feet later, cat5e ran for PA, NEC, and IP points.
House? What in the crap can all that cable run?I thought the same thing.
Then I zoomed in and I think thats a chase pipe/future conduit. So I was going to mention that plumbing pvc isn't pvc conduit.
There's also the issue with the cat5 and the 120/240 convergence on the left...
And many of those studs are now compromised as you said. But it's not my job or house so looks good
I used to pull a lot of cable. Just so you are aware...I learned (first heard of it being a thing about 2010 from vendor reps) and always abided by the fact that the plasticizers in network cabling can screw up plumbing pipe. In long-term contact, the plasticizers (you know how sometimes cheap cable feels "greasy") can supposedly chemically affect the PVC pipe and make it more brittle and prone to failure. Not so much a deal with plenum cable, but still a factor to consider, and good installation practice to maintain separation. Looks like you might need to watch that vent or drain on the far right, especially if insulation goes in that will mash the cat5 in contact with the PVC. More of a worry if it's a PVC water pipe under pressure, but still...
Not a heck of a lot online about this, but I go on the side of abundant caution. FWIW, YMMV, ETC...but the last one to touch it owns it.
Little-Known Installation Risk Can Mean Big Problems
ICF's soaking up the plasticizer
And BTW, damn, there's a lot of them studs half gone...counting the unused holes, too.
If you are going to spray foam you HAVE to encase that in conduit or....Good to know! Thanks. I’ll pass this along to the team. Planning on spray foam insulation.
Will be putting in more studs to compensate.
I was thinking that much tech warranted a planned raceway or channel. Holy crap I'm behind times if this goes into modern home design.
Apartments maybe? But dang my pee brain says plan for that stuff to go somewhere dedicated. Blue spaghetti makes my eyes hurt.
What is this in English? PA, NEC, and IP.
I've actually been reduced to using that exact same method before...do more with less is my employers motto
IIRC Simpson makes a reinforcement plate/channel that slips over the edge of a stud and nails/screws down. Really made for when a plumiot makes a too-big notch for a pipe.Good to know! Thanks. I’ll pass this along to the team. Planning on spray foam insulation.
There's several thoughts there.
If it's a new server in a commercial space, why are you running cat 5 at all. But that's a whole other convo.
Regarding future proofing ....pvc conduit and pvc plumbing pipe have different dims. So fittings, terminations etc won't fit right if at all. You have pvc plumbing pipe there not pvc conduit.
I'm not properly educated on wood frame construction methods, frankly your application doesnts seem wood frame appropriate to me but there are experts here on that and I'm not one of them.
Ignoring any structural or application concerns, if I was going to put cat5 in spray foam the only way I'd consider it is in conduit. If you simply cant/will not then at a minimum I'd run 2N cables to have spares for when issues start appearing.
Just overall you seem dead set on a high speed hard wired network and then everything about the install is not maximizing transmission speed or integrity.
