- Mar 20, 2005
- Hendersonville, NC
They're pointed the wrong direction if it maxes out at 12 mphExtra propulsion over some phat ass ledges
I run a stock 360 on propane with a Taurus fan and my shit overheats....WTH?
That could be possible but I've been running this set up for years without much issue. It's always ran warm, it is an AMC of course, but I still don't see why I should be getting as hot as I do now. Would timing have an effect?mid suspect you are too lean with your propane set up.
Timing too advanced has the same effect as a lean condition...That could be possible but I've been running this set up for years without much issue. It's always ran warm, it is an AMC of course, but I still don't see why I should be getting as hot as I do now. Would timing have an effect?
That's what I thought. I was always told to advance the timing until you got max vacuum. My engine drags like hell to get started. I guess I could always back off a bit.Timing too advanced has the same effect as a lean condition...
Just set it to 8-10* and call it about right. (Given age and wear)That's what I thought. I was always told to advance the timing until you got max vacuum. My engine drags like hell to get started. I guess I could always back off a bit.
daium, i knew they draw a lot cause I see it in the gauge and feel the drop in motor for a second lol but dang, didn't know they draw that much.You have dual Taurus fans? WTH for? Those things spike over 100 amps on start up.
My 11:1 400+ HP stroker with a stock 3.0 V6 radiator stays cool with a single one.
and I'm still unclear on what I need for better battery setup...should I order the solenoid relay thing which will allow me to install that second battery? or is the solenoid relay for these fans which will not need a second battery? tryin to get this done before this weekends wheeling trip, thanks
Everything has been already covered.
Go back in the thread, read it again, do what everyone told you to do, be happy.
I just used em cause I had em lol, they're not shrouded so now I see what you're getting at...shroud one fan would be much better, got it. So once I do this I shouldn't need a second battery? Thanks for bearing with meThe question is why do you need/have 2 Taurus fans? That's the level of airflow a KOH rear rad buggy would require. Not a 4.0 ZJ crawler.
Why not remove one of them at a minimum. That additional electricla load isn't doing you any favors.
Post a pic of the fan setup. I'm curious how you adapted 2 shrouded Taurus fans on a ZJ radiator.
Well so I thought, older style maybe? Mine look identical but no shrouds but I suppose now maybe they're not lol. They're high powered fans though, very thick wiring and keeps motor at 180 with no shrouds in placeWe're trying to help ya.
Here's a pic of a Taurus fan. Is this what you have 2 of on an XJ radiator?
2 separate fans side by side but no shroudsAre they 2 separate fans like what I posted or is it 2 fans made into one common housing?
Oh there is. I'm just wondering how he fit 2 Taurus fans on one.Are you trying to tell me theres no way to fit two 18" fans on an xj rad?
