Pipe repair at exit joint
RatLabGuy
Churchville, MD
Grrrrr
This drain line is leaking right around where it meets the exit like. Copper into what I'm assuming is cast. Our water is acidic and has slowly eaten mist of the copper away.
What is the best way to repair this?
Right now it's a slow drip, and only for the kitchen, so I need a quick patch (epoxy putty?)
But then the right way.... whatever that is...
Drain, you said...so not under pressure.
Had a cast-iron wye at my mom's house rusted thru after 40 years. When they built the house, the plumber had actually cut and shortened it, and brazed/welded back together. Epoxy putty patch over it 25 years ago and still holding.
Looks like brass to copper to cast
I know you're smart and all..but call the man
It's just copper into cast. May have a brass braze...? Its original from '67.
What would "the man" do? What is the proper way to fix it? Cut it off flush at the cast, and braze on a new fitting?
Couldn’t you get a shark bite fitting and go copper to pex? I’m no plumber. Just spitballing.
The leaky part of the copper is right in front of where it goes into the cast. Hairline crack in the bottom.
I feel your pain. My house is older. It has copper all over the place. It’s about time to crawl back under the house and do a leak check. I have a few with weeping joints and pinholes to keep an eye on. Nothing serious, just bugs my ocd.
Some sort of marine epoxy is probably your best short term “fix”
long term, get a dielectric Union between the copper and cast. Or, remove the copper entirely and replace with PVC and screw into the cast.
Edit... stupid me I completely overlooked the leaded joint on the tiny pic on my cheap phone. Lead in some stainless in place of the copper (if you can find anyone that can do it anymore).
He deals with it, so you don't have to.
This
Pulled time doing Lead and Oakum as well as repairs.
If you dont have the tools, nor a fernco coupler laying around...it really is just less effort to call the man
I assume it is a 2" pipe?
Remove the copper pipe and packing. Install a Fernco service weight donut into the cast, and insert the new pvc pipe into that.
This is pretty slick. I’m usually demolishing old cast for something modern. Or leading 10S stainless pipe into cast. But these fernco adapters are great for PVC.
They have this fiberglass wrap that's impregnated with epoxy you can use. You soak it then wrap it. Wait for a bit and then tighten the wrap again. It'll eventually set and you can call it good.
Cast iron is great pipe.... great at leaking after 50 years, I mean.
But what isnt?
Cast then Copper then Polybutyl were the answer til we learned they werent.
Then PVC, which is pretty good all around but has its limitation.
PEX seems to be the "new" normal...but who knows what it will look like in 50 years
But what isnt?
There isn't anything perfect. Cast and copper is about as good as it gets. The point is that anything as old as the stuff in Dave's picture just needs to get ripped the fuck out. It is past its useful life.
right so you agree everythign will be great at leaking after 50 years (or sooner)?
