marty79
the LS Swap Guy
- Nov 24, 2013
- Conover, NC
My new shop has this, and it works now that I got air to it. Anything I need to service/ know/do to it for maintenance or anything. Thank you
Yeah every shop I worked at with these we had thick steel tubing to keep it from slowly leaking down lol but at least this one has the safety lock on it.Go ahead and take the time to reseal it.. if you can. Every time I see one it's surrounded by kitty litter and is slowly leaking down.
You have to go underground!Yeah every shop I worked at with these we had thick steel tubing to keep it from slowly leaking down lol but at least this one has the safety lock on it.
So there's hydraulic fluid in it correct? How do you "add" or can you?
LolYou have to go underground!
Dont have one?!Somewhere on the floor away from the cylinder you will find a pipe cap or plug, make damn sure the system is vented of air before you loosen it. That’s the hydraulic tank fill.
I've used them I've never felt sketchy but I've also never put big ass trucks or suburbans on them either lolthose are notorious for suddenly swinging an arm and vehicles falling off. There are no locks
How is that possible if there is pressure on the arm? I must be missing something.Good luck, those are notorious for suddenly swinging an arm and vehicles falling off. There are no locks
Most of these types of failures are attributed to operator incompetence...How is that possible if there is pressure on the arm? I must be missing something.
"Make things idiot proof and you breed a better idiot."Most of these types of failures are attributed to operator incompetence...
Lol well ground is already considered contaminated since old gas tanks are still buried under parking lot so kinda good for me lol, why house and shop has to be on city water not well anymorebe sure the oil hasn’t leaked into the ground and groundwater because you will be buying the environmental issue along with it.
It was all covered/ taken care of and approved by city before deal was made so all is goodSeems there was some Federal mandate, Years ago, to remove the old tanks, or maybe fill them with sand, concrete, something. You may be ok, as long as no contamination leaves the property. If it does, your SOL! If you bought it, tanks & all, I'm somewhat surprised! Didn't think the property could be sold with in Steel in ground tanks. Maybe a Disclosure covered the PO?
All adjacent properties were already forced to switch to city water, as mentioned it's all been taken care ofso they are ok with the sale, but that in no way relieves the owner (previous or new) of any liability for groundwater contamination. The gov doesn’t care about your own well, they very much so care about wells on adjacent properties. This is where your risk lies and has been known to cost millions to owners for clean up.
If it’s like any of the others I’ve seen, it changes it’s hydraulic oil by leaking into the ground and you constantly have to keep adding and adding. Most shops I’ve seen have switched to the 2 post lifts.
if you are buying the property, be sure the oil hasn’t leaked into the ground and groundwater because you will be buying the environmental issue along with it.
