Croatan_Kid
How's your hammer hangin'?
- Nov 4, 2007
- New Bern
Yeah...what was I thinking? Who would want a longer driveshaft with more available operating angle?
Hey man quality and durability are useless. If what I have works what could be betterYeah...what was I thinking? Who would want a longer driveshaft with more available operating angle?![]()
Hey hey it's his jeep, his wants. I'm just the guy doing what he wants. This isn't an off road jeep btwYeah...what was I thinking? Who would want a longer driveshaft with more available operating angle?![]()
Here's the layout, no it's still giving me the same code..maf low circuit input p0102.You ever figure out the MAF issue?
Are you measuring cooling system pressure or just assuming it's "too pressurized?" This temps are fine, most stock truck ls stuff runs 195-210.Here's the layout, no it's still giving me the same code..maf low circuit input p0102.
And cooling system still not quite right. It's running at 185 idling, 177 driving but upper hose is still too pressurized and lower thermostat hose still not all the way hot. Do I just assume new thermostat is janky or somehow still air in the system?
No but judging it by how the upper hose should feel..its too stiff for what I'm used to. Plus the thermostat lower hose should be much hotter than it feels. Idk maybe im overanalyzingAre you measuring cooling system pressure or just assuming it's "too pressurized?" This temps are fine, most stock truck ls stuff runs 195-210.
Without putting a pressure gauge on it then you're guessing. The upper hose should be hotter than the lower hose. Upper is the water pump outlet and lower is the inlet.No but judging it by how the upper hose should feel..its too stiff for what I'm used to. Plus the thermostat lower hose should be much hotter than it feels. Idk maybe im overanalyzing
I'll try cleaning it tomorrow and yeah I got the coolant sensors moved to where they're straight in the head like factory now.Try cleaning the MAF.
Did you ever get the coolant temp sensor IN the flow of coolant? How are the fans controlled and when do they turn on/off?
It's amazing how awesome 225 rwhp and 285 rwtq feels.
dang that much? holy cow.Rear wheel. Advertised numbers are at the crank. You lose around 20% through an automatic driveline, plus, it's 20 years old and has probably lost a few horse torques.
good to knowIt uses the MAF to actually measure air flow, not calculate it based on its density. The MAF also houses the IAT sensor. You can run an LS without a MAF in a speed density tune, but there's absolutely no point in this case. It would require a tune change, a full rewrite to license it, and you'd have to wire in a separate IAT sensor.
Is it alliance hose or alamance hose? Alliance comes up but alamance doesn'tI was just there this morning. Two custom ac hoses were $54.00. I supplied some of the ends was pleased with the price and quality.
Thank you.Yea it is Alliance Hose and Tube. They are on South Elm-Eugene. 336-378-9736.
are you on to the next one now?just wanted to give a big thanks to all that helped me through this LS swap for my first time. Thanks to everyone for taking your time to guide me through this process!!
Nope I'm taking time off to build mine dang it.are you on to the next one now?
