Yeap and a couple JeepstersI love the fact that there are some other Bullnose guys on NC4x4. Definitely a dying breed
I had that same run on issue with my old CJ5 when I put the MSD on it. Mine took a tiny little white diode with black stripe on the white wire coming off the alternator.It took a while but I got the engine running. I had two gremlins that I needed to work out. The first was the run on issue for the MSD system. And the other was the transmission would not shift.
The MSD issue required a big old style diode. It took a call to Holley to get it figured out, but once it was wired right it completely took care of the problem!
The shift issue was a vacuum leak on the transmission actuator. So put a new piece of hose on it and everything started working.
At this point I just needed to figure out the valve tapping.
Oddly, I remember when this happened to yours (20 years ago) and knew what to do when it happened to mine (don't recall if it was when doing the electronic ignition 18 years ago or TBI swap 12 years ago), but immediately knew the cause, grabbed the diode, and all was good...I had that same run on issue with my old CJ5 when I put the MSD on it. Mine took a tiny little white diode with black stripe on the white wire coming off the alternator.
Funny how I can remember that from 20 years ago, but don’t recall what I had for lunch 2 days ago.![]()
