DSM Turbos
- Feb 25, 2006
- Raleigh, NC
The boat and multiple bikes says this ideology is flawed![]()
Nobody asked for your opinion!
For the record, I have less bikes now then 2 years ago
Superjoints and drive flanges.Nice, now you can "throw all the LS at it" like the rest of the idiots... myself included
Explain beef up the front diff please. Like load bolt or??
ahhh, thought you was going to do some super voodoo lp60 magic that only those of gear and axle magicians understand.Superjoints and drive flanges.
It has chromo shafts but stock joints. The locking hubs were assembled incorrectly and show wear. I grabbed my spare TeraFlex drive flanges out of my spare parts box and will use them.
I'll pop the carrier out and verify the diff is bueno also.
Once I get the carrier out that's what I will do. There are a few tricks to making a low pinion 60 liveahhh, thought you was going to do some super voodoo lp60 magic that only those of gear and axle magicians understand.
) the decision has been made.You gonna bring the Enduro joint rebuild kits or should we order them now?Let me know if you decide to get a trip together, I might tag along if you'll let me.
Why going back to AL fenders when they notoriously suck at being strong ?.
Thanks to @77GreenMachine drive by braille technique, new fenders were in order.
Luckily we all know Genright sells fenders at amazingly low prices
I am a man of great restraint and finesse.Why going back to AL fenders when they notoriously suck at being strong ?
Hopefully you have the new and improved version, but I can rustle up a few spare parts if you need them.You gonna bring the Enduro joint rebuild kits or should we order them now?![]()
And if you don't pick me up in B-lair on the way there, you suck.You better tell me if you go to Gulches!
You should see my matching cut offs
Is it on the way from Camden to Gulches? Not sure where you are these days.And if you don't pick me up in B-lair on the way there, you suck.
Eww... no!You should see my matching cut offs
Most of the time I don't either.Is it on the way from Camden to Gulches? Not sure where you are these days
AGREEEEEEEEEEEEEEEEEEEEEEE. Now imagine having one in front application and using it as a battering ram because you drive like Ray Charles.That rear diff cover gave me a hard time, and had some wonky bolts that got thrown in it in a pinch before a trip. It leaked less than before after that so I was scared to touch it again lol.
I do not recommend the weld on shave kit on a 14 bolt. Simply cutting the bottom off a little and running a 13 bolt cover is the best way. Curse the guy that did that to that Jeep.
Driving by braille is a talentAGREEEEEEEEEEEEEEEEEEEEEEE. Now imagine having one in front application and using it as a battering ram because you drive like Ray Charles.
I'll probably weld a piece of 3/8" round stock to the bottom of the diff to give a little lip protectionAGREEEEEEEEEEEEEEEEEEEEEEE. Now imagine having one in front application and using it as a battering ram because you drive like Ray Charles.
Had planned to or did (really can't remember) weld a plate to the bottom to try and help but the above mentioned driving styles were at play.My front cover is bent in backwards. I mean thats technically what its there forDriving by braille is a talent
