StretchASU
Playing country music til Troy's ears bleed.
- Oct 17, 2006
- Claudville, VA
Finally got an evening to pull the case that made so much noise. She’s toast.
Gasket maker is setting up on the reassembled TJ case and everything spins and cycles fine.
. I did change out the front rotors, pads and did a vac bleed on it a few weeks ago. It had always had a low pedal after the 8.8 swap even after
