tlucier
- Jun 3, 2007
- Mebane, NC
Good eye…damn good eye! I missed that.The big problem I see with that is the anti-clockwise wrap around the screw. Sheesh, amateurs.
You start having more kids you will have to start selling all them toys.I guess I need a couple more kids.
Actually it’s been the opposite in the past few years. Been buying toys “for the family” or “for the kids” hahaYou start having more kids you will have to start selling all them toys.
I see you've trained with @jeepinmatt Well done grasshopper!When you’re trying to get a new piece of machinery ready to put in place and you have to boot the squatters. Biggest damn wasps I’ve ever seen
Brake clean is definitely much more fun, but I have sound out that wasp killer is cleaner and quicker…. And much safer on my vinyl sidingWhen you’re trying to get a new piece of machinery ready to put in place and you have to boot the squatters. Biggest damn wasps I’ve ever seen
Been looking at suitcase welders for a few weeks and hadn't made my mind up. Got a crew at work doing some work and one of them has the little miller and the other had one I didn't recognize. I looked it up and it's $100 on Amazon?! Dudes rig is beat all up but cooking metal just as good as the other guys miller. I just bought one. Will report back when it use it.
I have real welders for heavy stuff. I just wanted something for when I need to weld one little thing way over there and don't want to drag out the big welder. If it sucks I'm only out $110One of our subs on my site has a couple if these. Hasn't had any issues passing inspections, but has fought that machine every step of the way. Is it user error? Maybe, maybe not. Maybe it just doesn't have enough duty cycle.
I'd but one in a heartbeat for personal use (actually planning to put one in the farm truck) but I wouldn't buy one for everyday heavy use on site.
search swamp buckets…. I love a good low country boil. Seen these online but knew I could make one. Makes it easy of it turns out. 35$ vs 140ish after shipping. I know the plastic is concerning. I did wipe my new bucket down with disinfectant and then boiled 2 batches of water to sterilize it. Making a boil now. Plastic doesn’t seem to get soft or anything of that matter. Drilled holes in the lid, turn it up and strain the food
That probably has a melting point around 250 deg. So you aren't far off.search swamp buckets…. I love a good low country boil. Seen these online but knew I could make one. Makes it easy of it turns out. 35$ vs 140ish after shipping. I know the plastic is concerning. I did wipe my new bucket down with disinfectant and then boiled 2 batches of water to sterilize it. Making a boil now. Plastic doesn’t seem to get soft or anything of that matter. Drilled holes in the lid, turn it up and strain the food
Didn’t even get soft at a hard boil. Just a convenient way to boilThat probably has a melting point around 250 deg. So you aren't far off.
I have real welders for heavy stuff. I just wanted something for when I need to weld one little thing way over there and don't want to drag out the big welder. If it sucks I'm only out $110![]()
What radiator is it getting?Back in the shop for a bit. Forgot about a few projects I had committed to.
Too hot to wheel anyway. May as well make some coin in case there's a hole in one of the pistons of my RangerView attachment 420833View attachment 420834
The Shawn Clemons special: Be CoolWhat radiator is it getting?
Very cool. Got a link to the heating element? I’ve downsized and all my gear is in storage. This would be very handy!Didn’t even get soft at a hard boil. Just a convenient way to boil
Some food for thought (pun intended)Didn’t even get soft at a hard boil. Just a convenient way to boil
Yes, food grade bucket is ordered. This is a got what they had trial. The lid is good grade so won’t have to buy that againSome food for thought (pun intended)
Sterility isn't your problem. Those buckets are made from HDPE, which as a glass temp of ~120 C. Its above boiling, but not by a ton, and its really a range of ~100 to 130, so you're riiiight on the edge (glass temp isn't a hard line)
The real problem though isn't the softening as much as offgassing and any breakdown and release of polymers from approaching that range. If its soft at all you can guarantee you have microplastics in your food.
HDPE is recyclable (#2 IIRC). There is such thing as "food grade HDPE", which means it is specifically made from virgin materials so its known to be pure.
If its not food grade, which of course the buckets aren't, then there some very good but unknown chance its made from recycled material which isn't required to be disclosed. And bein grecycled there's a good chance it isn't pure, and the offgassing may be releasing "just" HDPE, or could be other unknown stuff.
Did you die? No. Will you die if you do it again? Also probably no.
Is it a good idea to do this as a habit?
I sure as hell wouldn't.
I'd at least buy a food grade bucket![]()
What ^ said. @Noel spend $25 so you don't die of plastic bucket induced penis cancer in 10 years:Some food for thought (pun intended)
