Getting the samurai to Harlan
I thought I saw you there in the campground one time I was passing through.
We didn’t camp at the ranch but we parked the tow rig behind the arena on Friday and Saturday.
I’ve been having some problems keeping the engine cool when going slow in the rocks.
My old fan was one that was laying in the back of the geo engine donor I bought. No clue what it came from and it didn’t cover the whole radiator. It was too thick to run any sort of shroud. I fabbed a new shroud with some sheets of abs plastic. And got a thin 14in fan.
It’s clears the water pump by just enough to not be worried about it. I used some jumper wires to turn it on and it holds a sheet of paper flat against the grille with the fan running, so it has good air flow now.
I’m trying to improve my wiring skills, So it got wired in with a Dtp connector and the chassis side got some cloth loom.
It’s been a while since I worked on this because I’ve been working on a large house project. I’m done with that for now so I can get to my gears and rear axle swap.
I cleaned the old brackets off the Dana 44 and welded on new spring perches and welded the axle tubes to the center section.
I’m working on getting the 5.13s installed. Revolution gear is having to send me ring gear bolts because the ones in the install kit were the wrong size.
Picked up one of those little 120v stick welders to take on trips. It runs 1/8 7018 ok and was only $68
I got a camper shell for the tow rig since it got so cold in the tent last year.
We have an October trip to Karios planned so I’m trying to get everything done and tested before that.
Dropped the Dana 30 out on the lift. I’m honestly surprised the welds holding the tie rod from moving never broke.
Once the Dana 44 was bolted to the leaf springs I could see that the traction bar mount was going to be up on the casting of the center section. I reused the traction bar mount from the old rear axle.
Made custom brake lines for the new axle. I used the hoses from the old setup. The they are tj front hoses at the caliper. The hose that drops to the axle is a rear hose for a lifted tj.
The rear driveshaft was too long so I had to shorten it up.
I got the front axle geared and started removing the fender flares. They were rubbing with the 31s. So no way they would clear the new tires.
Flexed out on the engine hoist and found the rear was pretty close to clearing. Just some slight sheet metal trimming and it was good.
A before shot of the front fenders before trimming for the new tires.
And after. It stills rubs a little in the front but I don’t want to rework the front bumper more.
I saw a rear steer truck coming through an intersection in front of me yesterday and immediately thought about this thread. They're just really cool trucks for some reason!
Keep up the good work :D
Got all the roxzillas mounted, wiring secured under the hood. And ready for a shakedown at uwharrie
I haven’t updated this in a while. I didn’t really do anything after the shake down run for a while. The tires make such a huge difference. And the gearing is about right. It will bog down some but I try to just roll into the throttle when I need more torque.
The trip to kairos wasn’t really a good wheeling trip. The camping with the family was good but we only found the one rock crawling trail and it wasn’t anything to write home about. Wish we had just gone to ger.
I did another frame swap at home so my shop was tied up for a while.
I had a fueling issue sometimes that after some brain storming I decided the fuel pump just didn’t have enough pressure on steep climbs. My old one was a 2psi pump. I got another Holley pump that’s a 4 psi and it seems to be fixed.
The uhmw pipe on the traction bar works so good I wanted to try it on my front lower links.
We went to ger in April and it was an awesome trip. I had the underdog rig since the group was mostly buggy’s.
I decided to try cripple creek the second day and made it without winching and only needed a spotter twice. These tires are magic lol. We ran all of the hard trails I know are there. It even walked can opener with no trouble. I had to winch there last year.
I did get stuck in the honey hole when I tried to bump it and got hung up on the rear leaf springs. Lost a bunch of transmission fluid out of the shifter.
Twice I tried to use my winch at the ranch and it didn’t work when I was pointing uphill for some reason. The rough country 6500 side by side winch has been on my radar for a while as an upgrade/weight savings, so I ordered one when we got back.
It fits in front of the radiator where my old Ramsey 8000 was under the radiator.
Synthetic rope and wireless remote are a big upgrade too!
Your sami is badass, awesome meeting and wheeling with you a few weeks ago!
We’re planning on buying some sort of enclosed trailer we can camp in at some point so we can have ac and heat when we’re traveling to different Offroad parks.
I bought a used b&w turnover ball hitch for the quadrasteer. It had some rust so I removed all the old powder coating and painted it with rust bullet.
I had been looking at market place knowing I was going to wrap up my hitch installation. I found this enclosed and went to check it out.
It should fit our needs pretty good. It has rooftop ac with a heat strip, it’s wired with some outlets. Since someone who raced circle track owned it before, it has an observation platform with fold up railings too. It hasn’t run in almost 10 years, but it has a onan 4000 generator in the front storage compartment.
I test fit the samurai and there is plenty of room.
We are going to add a sink/small water heater and a mini fridge
I had wanted to upgrade the quadrasteer transmission cooler already because sometimes it will get warm pulling a grade in 3rd gear since the converter is unlocked. My research lead me to the tru-cool 40k
Plumbed it in with more an hose. I had done some of these already to delete the factory rubber transmission lines that were leaking.
We went on a camping trip to test out the new trailer at arrow head campground. It went ok, the heat on the rooftop unit doesn’t work but I packed the electric space heaters.
You know...
I'll have a spare LB7 drivetrain on my hands before too long. A Dmax quadra-steer would be kinda cool :D
You know...
As cool as that would be, I have done the math on a diesel truck. It doesn’t work out for me.
I wish I had the time to maintain my vehicles how you do. But everyone knows mechanics don’t fix their own stuff lol
Some days I wish I had found a 3500 frame instead of the 2500 so I could have a heavier duty truck. Before I got the quadrasteer I wanted a 3500 dually with a flat bed.
I don't do anything special. Change the oil, fuel filters, transmission stuff...everything else is replacing stuff because I want to and I make bad financial decisions :lol:
Plus...there's no mathematical equation for being freaking awesome :huggy: :D
I was checking over the samurai because I wanted to make a run to uwharrie on Veterans Day and found the steering box mount cracked and the frame near it cracked. It’s taken a lot of abuse since I don’t have hydro assist.
I’ve had this on the shelf for a couple months but haven’t bought an orbital or a Clevis kit yet. So I’m going to groove out the cracks and weld it, to make it too the gtg ride hopefully.
And after a 2 week stay in the nicu my boy should be coming home!
I have been working on converting the Sami to full hydraulic steering finally.
I wanted minimalist mounting with the best tie rod angles and ground clearance.
Braced the back up to take some side to side forces, before I capped the top.
The cylinder clears everything at full bump
It spans from the center section to the upper link mount so it’s locked in side to side.
Instead of buying a Clevis kit for $160 i made these plates to weld to the tie rod, like the goat built kit.
I cut up my old tie rod to make the pieces for the small ones.
Part of my plan to be lightweight is a thick plastic skid. I got some 3/4 hdpe and some counter sunk bolts. It is flush with the bottom of the axle tube
I made the end pieces out of angle iron and tapped holes for the bolts
I trimmed the front down to a decent looking profile. My plan for a suck down winch is to put a soft shackle around the steering ram.
I got the orbital mounted. I had to trim the fender well some to get it where I wanted.
For managing the hoses I used a mounting block to keep everything clear of the engine and suspension components.
Everything is ready for a shakedown run soon
