gslander
- Aug 13, 2021
- Hickory, NC
You no longer have the Tacoma?I miss it.
No, he sold it a few years ago. Pretty sure I've seen it change hands a couple more times on Facebook.You no longer have the Tacoma?
Cucv (M1008, m1009, m1010, m1028, m1031) were just base model trucks and blazers (m1009) that had the heaviest suspensions available and all had 6.2 non emissions J code diesels with turbo 400 transmissions and either a np208 or some versions had the np205 for its PTO ability such as the m1031 maintenance truck to run the generator. All the trucks had Dana 60 fronts with the m1008 being open and the 28 and 31s had a trac loc limited slip. Most trucks had the 14bolt rear except the dually versions had the Dana 70. All trucks had 4.56 gears and that's why they always get stripped for the axles: low gears and traction aids and they never saw big power or abuse in service. All blazers had 10bolts with 308 gears with the GM govloc wind up locker. All were 24volt starting and charging systems to be NATO compliant but everything else on the trucks are 12volt and converting them to 12v is common and easy. These are just the highlights, there's some other differences like blackout lightning and other small things.What are the differences between a M1008 and a typical square body?
I wish, I had to let my 75 K10 project go; after a month of straight catastrophes I had to prioritize my project list and free up some extra cashM1008 with typical square body mods including torch cut 8inch shackles up front. It's available if you're interested. Just rolled it off the trailer last night and fired it up today.
Nah, sold it and bought another tundra. Got too many vehicles, couldn't justify keeping it. I'll probably pick up another dependable beater at some point. I did buy a Honda Foreman yesterday. Planning on getting back up to harlan at some point and other places as well.You no longer have the Tacoma?
Too much weepoww. That sucks.The engine in the buggy had a disco party yesterday at the Ranch. Bit too much weepow and angry squirrel noises. Ended up locking up and having to be dragged back to the trailer. Today I cleaned up the buggy and dropped the oil pan to see the damage.
Cylinder #1 rod bearing left the chat. Rod side bearing actually rolled on top of the cap side bearing.
Now I have to get one of the spare engines out of the shed and go through it to make sure it's ok to install.
View attachment 454399View attachment 454400View attachment 454401View attachment 454402
Or have an interiorYou actually wired the gauges up, SEMA build wouldn't have done that![]()
Eff it, run it.Trying to figure this out today and of course didn’t plan ahead and buy 2.25” pipe
View attachment 454633View attachment 454634View attachment 454635
Called a couple local muffler shops and they all quoted between $150 and $200 for them to bend me three 90s.
Overnighted some from Amazon for $50… sorry local guys but that’s crazy
Vid was too large to post so y’all get a insta link
I HAD to crank it with the open headers.
Now that I’ve “tested” the exhaust I’m going to pull the collector back off and paint with the same aluminum paint I did the rest of the system with, once that’s cured I’ll wrap it then that will be done!
I triedNo worky.
I could view itI tried![]()
