My first engine “build”
Sooo, I haven’t really updated this thread in awhile. I’ve been dropping updates in the “what have you done o your rig thread instead”. Thought I’d give a little update here.
At this point, the engine and drive train are in. I’ve been working on fit and fitment, cleaning things up, figuring various aspects out and trying to wrap up the last few steps. You know… all those steps that take a lot of detail and attention.
After much back and forth, a lot of research, managing finances, against my preference at this time, I’m going with the 4.0 header, 258 intake, and MC2100 carb with an HEI ignition.
I have enough expense to finish out what I have now with that set up, to not worry about added expenses of a better intake or fuel jnj action at this time. Luckily, that all easy enough to revisit at a later date and not have to spend money on this set up for now.
So, what I ran into. With the automatic column actuated shift linkage, the header collector pointed right at the shift linkage bracket. I did find that I had my transmission mount in the wrong location, and that didn’t help. So I moved that the other day. This shifted the tail housing to drinker side and that helped, but not enough. Then yesterday I realized that I had the 4.0 motor mount brackets on instead of the 258 motor mount brackets. Swapped those today and that again shifted things again and centered and aligned the motor in the engine bay.
So with that, I still needed to modify the header and the shift linkage bracket. So, out came the ankle grinder.
Need to run over to my cousins house to weld this up, but it’s going to fit quite nice now.
Next is the intake. Had to grind down the alignment tabs on the bottom side to get the correct alignment with the head intake ports. That wasn’t too bad. Just need to fab up some custom washers to grip the intake flanges and bolt the intake down.
Note the motor mount bracket in this photo is the 4.0 version. Differentiated by the through hole location for the bolt. It’s lower and more inboard. You’ll see the difference in a later image.
So today, changed motor mount brackets, re routed electrical for fuel pump from firewall and took it through the interior instead of down the firewall and under the tub as it has been.
Played with cleaning up wiring and took a look at the loom wrap. Probably just procrastinating trying to figure out electrical as I just love it so much… 🙄
(Note motor mount bracket in this photo)
Learning loads in this process! So that’s cool.
The carb/ hei is a great combo, easy to troubleshoot too and no points to maintain
Ugh… have I ever told you guys how much I hate electrical?
And while I’m complaining about electrical (mostly due to my ineptness with understanding it) when lookmup reference materials and videos, why this hell don’t wire colors, gauges, locations, routing match up?
Example, one reference says “look for the 12ga red wire spliced to the blue wire….” Mine is a yellow 18ga spliced to a brown and black.”
And mine is obviously factory wiring.
Gonna go find my CJ Hanes Manual from the late 90’s (old enough to not have to explain that you don’t drink battery acid). To see if the wiring for it might be A good cross reference. At least the way those are drawn, I’ve always had an easier time reading. Not a fan of the TSM version drawings that I have.
Ok, figured out some more of the wiring and m down to the ignition and the charging system. I’ll figure the charging system out when I get to the alternator selection.
For now, Ignition. I think I have it figured out, but before I cut wires, I’m looking for some confirmation.
Refresher, I’m going from stock 4.0 distributor ignition to HEI.i have 4 wires. If I have this correct, OE green to distributor goes to green on HEI for Tach.
leaves me with black resistance wife from Alternator that needs to be pulled from the Oe harness and moved to alternator and spliced to power wire on distributor.
Red with grey trace wire that came off yellow and goes to coil and solenoid can be removed.
Yellow needs to be replaced with a minimum 12ga wire to red light on distributor because of the HEI.
Then I need to connect the power to the starter solenoid.
Can anyone confirm or correct?
MOTHER FLETCHER!
Yesterday I dumped a gallon of ATF in transmission just to check for leaks and to have some in the pan because I’m hopefully getting close.
This morning I rolled underneath and found the rear of the pan wet. Tracing everything it’s the trans pan gasket. I wiped everything clean, checked torque on pan bolts, continued with other work, looked again and wet. FAWK! Gotta drop the pan and reseal.
What’s everyone theory on cork gaskets? I e heard nothing needed, bolt it and go, I’ve heard a thin coat of rtf for good measure.
I went with nothing. Going back with a little rtf at this point.
And WhyTF wouldn’t they put a drain plug on a pan? Seriously! There is a nice low point dimple! FAAAAWK!
MOTHER FLETCHER!
I rub rtv on both sides of gaskets to get a thin layer it doesn’t squeeze out as much that way
Ya, inspecting the cork gaskets, it looked over torqued and mashed. Front half of pan gasket was dry around the outer edge, rear half wet through and through. And at least one of the bolt holes was split. So, self inflicted wounds. Tight ain’t necessarily tight. It might be over tight. 🙄
Ok, so, with the job/income hunt on, my schedule over the past weeks has been, up at 7, coffee, peruse the classified (a term for you old old, maybe). 8-11or 12 on the jeep, and the afternoons to see if anyone has replied to applications, do some more applying, and research my own gig that maybe I’ll post at a later date assuming I get it up and running.
So, where I’m at.
With lack of income at this moment and wanting to keep forward momentum on the jeep, I’ve opted to use the 258 intake and MC2100 to deliver fuel and air to the 4.0. I still have the 4.0 fuel
Injection and computers for a later date if desired, but to be honest, I’m leaning toward a Clifford 6=8 intake set up when funds approve such a move.
I just like the idea of no computer, to be honest.
So, modified the intake to match the intake ports on the 4.0. The 258 intake and exhaust ports are different than the 4.0. The 4.0 intakes sits higher. Some people completely grind off the tabs and alignment holes on the 258 intake, I just alingned and marked and ground them back to where the tabs just sat on top of the alignment pins in the head. Some people even grind off the alignment pins on the head. I’d rather not and save them for a later date seeing as the intake will be trashed before the head.
The next hurdle was the flange thickness of the 258 intake and the 4.0 header. As well as the offset from moving the intake up about 5/8”.
I took some 1/4” flat bar, cut out And drilled some tabs, then bent them to fit and clamp the header and the intake. Had to do them one by one and this was very time consuming. But in the end, everything was tight and clamped. Fingers crossed for no leaks!
Next was the alternator. The engine seems to sit slightly passenger side, so with the new brake lines, I had no clearance for the alternator. Looks like I’ll just take the brake line up and over the frame rail. Seems to clear, everything fits. Calling it good to go.
Since the intake was moved up about 5/8”, anyone want to guess what the next issue is?
Bueller, Bueller?
What mounts to the block as well as the intake? That’s right, the power steering…
Two bolts mount the 4.0 power steering to the intake. I ended up being able to use one. Luckily there was enough meat in the casting. But I will need to RTV the hole as it does pass through into the intake plenum. Everything is just fitted up for now in the photos. I need to pull the intake and vacuum out the passages and tap one more hole for the AC vacuum control.
Oh, and the trans no longer leaks, the header collector has been realigned and welded up, the shift linkage bracket has been modified to clear the header collector and… well.. the past few days have been productive.
Enjoy some PICTs.
Intake pulled, cleaned and reinstalled. Glad I did as there were some nasty thread cuttings in there.
Fuel delivery installed, alternator and power steering installed sans a the high pressure line at this point.
Serpentine belt installed…oh! And I didn’t realize, but I found that I actually had a T-60 torx to remove the 90* adapter for the oil filter and deleted it. Sometimes it’s nice to run through your tools for a refresher on what you have!
Now, after a few steps forward, it’s time for the steps back. After cleaning and reinstalling the trans pan, then filling with fluid again, I have a leak coming from between the trans tail housing and the t-case. I do not have a gasket between them. Not sure if I should. With a seal on the transmission output shaft and a seal on the input for the tcase, I figured this area was void of fluid. Maybe I’m wrong? Anyone?
Oooo the anxiety is growing getting closer to being done!! Starting to look like an engine bay again!
There is a gasket there
FEL-PRO 55484 is the generic fits all the 90s transfer case part numbers, usually at every orielys for around $25 the jeep specific ones are hard to find outside of a full seal kit
If you can wait on shipping
