Pulled the intake to replace the gaskets after 30 years and screwed up I guess cause now it is leaking oil bad under WOT... also.... talk me out of a 383ci cause this bitch is lacking some HP (not like it jad any to begin with) and a SBC will be easier and less new parts then an LS.
Pulled the intake to replace the gaskets after 30 years and screwed up I guess cause now it is leaking oil bad under WOT... also.... talk me out of a 383ci cause this bitch is lacking some HP (not like it jad any to begin with) and a SBC will be easier and less new parts then an LS.View attachment 459354
Story of my life. “I should probably replace these old lines/gaskets/etc.” now it’s worse
Don't drive it at WOT.....half the problem solved!!!
If it was me I’d just find a bulk oil supplier. Since it’s you, I vote 383!
