Need to get the dash in so I can install the Genright console and start on shifters and wiring. I knew there was some clearance issues with the dash, HVAC ductwork and the cage. I didn't know just how much.
Ended up removing the OEM HVAC assembly. Also had to strip the dash down to the metal frame to cut it away from the cage tubes going to the floor. I wasn't expecting to do so as I *was* thinking about getting the AC working eventually. But alas, I'll toss a hot rod style heater in it and call it done.
It definitely is looking more finished inside. I have all of the OEM dash trim and pieces and will install them later.
View attachment 459713View attachment 459714
On to.the corners and rocker guards. Got the driver's side done today. I marked the fenders for cutting and will do that this week. The corners are being painted body color and the rockers will be black. Kinda sucked taking a plasma cutter to a $500 set of rockers. But they're made for an OEM tub/frame combo, not this one. Regardless, I have some scraps for the front corner piece I wanna add later.
I'll start on the passenger side tomorrow after work since I kinda have a system now.
Initial mock up
Essentially bolted down (aside from one crooked nutsert)
I'll add a piece to match the angle of the WOD fender line this week (both sides)
