StretchASU
Playing country music til Troy's ears bleed.
- Oct 17, 2006
- Claudville, VA
YesDoes Reba like the long one or the short and fat one?
She been riding the short and fat for about six years nowDoes Reba like the long one or the short and fat one?
One for the front and one for the rear.Does Reba like the long one or the short and fat one?
If you want to borrow the plasma cutter give me a shout.Need to get the dash in so I can install the Genright console and start on shifters and wiring. I knew there was some clearance issues with the dash, HVAC ductwork and the cage. I didn't know just how much.
Ended up removing the OEM HVAC assembly. Also had to strip the dash down to the metal frame to cut it away from the cage tubes going to the floor. I wasn't expecting to do so as I *was* thinking about getting the AC working eventually. But alas, I'll toss a hot rod style heater in it and call it done.
It definitely is looking more finished inside. I have all of the OEM dash trim and pieces and will install them later.
View attachment 459713View attachment 459714
On to.the corners and rocker guards. Got the driver's side done today. I marked the fenders for cutting and will do that this week. The corners are being painted body color and the rockers will be black. Kinda sucked taking a plasma cutter to a $500 set of rockers. But they're made for an OEM tub/frame combo, not this one. Regardless, I have some scraps for the front corner piece I wanna add later.
I'll start on the passenger side tomorrow after work since I kinda have a system now.
Initial mock up
Essentially bolted down (aside from one crooked nutsert)
I'll add a piece to match the angle of the WOD fender line this week (both sides)
My 80 amp unit has been putting in the work!If you want to borrow the plasma cutter give me a shout.
Yes for serviceability. Like an OEM application would be.Is adding soft fuel lines at the fuel cell mainly for serviceability? Did you decide on stainless lines or aluminum?
Nickel copper for ease of useYes for serviceability. Like an OEM application would be.
Unsure on aluminum or SS yet.
Brake lines probably will be Nickel/copper.Nickel copper for ease of use
How is it there aren't any pictures on this entire page? This build thread sucks.
//thread.View attachment 459854
Happy now?
3/8 Nicop straightened from a roll will be easier than stainless to get to seal, I couldn’t imagine trying to trail fix a stainless line. Aluminum will corrode (fittings are different since they’re anodized and the connections on aluminum are really hard to get a good flare without cracksBrake lines probably will be Nickel/copper.
The fuel and trans bends will be 90* and 135* in a lot of places. I'd prefer the straight runs to be straight as opposed to straightened roll tubing.
They have annealed stainless that flairs nicely3/8 Nicop straightened from a roll will be easier than stainless to get to seal, I couldn’t imagine trying to trail fix a stainless line. Aluminum will corrode (fittings are different since they’re anodized and the connections on aluminum are really hard to get a good flare without cracks
Beat me to it.They have annealed stainless that flairs nicely
You are killing it I think… your turn around time is really fast considering life exists beyond the build.
= Damn, you can get a lot done when you don't have kids!
Yeah along to a later date on the calendar…But the kids are always such a big help, they really move progress along.....
Duane
I have the hydro brake line flaring tool if you need that also.Beat me to it.
When Cutler and I spoke, he made it clear to use annealed SS. He sent me a video of what tools to use with it specifically too.
Whether or not I invest in the tools for a one time use thing is yet to be determined. That would be the only reason I go with aluminum.
My Ranger was plumbed with aluminum on the frame rails and runs of braided to the rails. Worked just fine. I want it cleaner this time regardless of aluminum vs SS
Awesome. Once I decide which way I'm going to go I may take you up on thatI have the hydro brake line flaring tool if you need that also.
