SXOR single seater build
Absolutely! I killed my beadbuster from use and bought the HF HD version. What a time saver they are!!!!
I got the XB550i, it’s a little more HD than the standard one. It says it will do up to tractor tires. My M18 3/8” impact worked perfect on it.
I have that one too. Broke and fixed twice at least. Usually the roll pin in the nut gets sheared with the 1/2 impact. I've done my H1's regular 15's and 17's and the old ford tractor tires.
Got the shafts and hubs installed this morning. Need to grease the joints and install and bleed the brakes.
Reason I ask is because I had a couple of my CTM caps walk so I started tacking them. I've read others having the same issue. 👍
I’ve definitely heard those stories too. I had planned to do the loctite bearing retainer compound on the caps. I forgot it when I assembled them. So I asked Lee if I should and he said he’s never had any issues with them.
I got the brakes bolted up yesterday morning.
My old Stazworks wheels don’t fit over the ‘05+ hubs. The center bore needs to be opened up about .030”. We’re on the way to the beach right now so I’ll take them to get machined when we get back next week.
The 39” Reds sold yesterday too so I’ll be ordering some 43s when we get back as well.
This thing has been on jack stands since 2018 sooo… :laughing:
But you didn’t sell out! That’s the main thing. Jabs intended to everyone else.
A few days ago I got the steering bled. After bleeding the steering I started it and let it warm up to temp. It’s still running on almost 8 year old gas. :laughing:
Also got the new Wilwood single MC bench bled. Need to install it and bleed the brakes.
And these were delivered to my place of employment on Friday. Nobody there seemed to want or need them so I’m going to bring them home with me.
I worked an outage at my most remote compressor station all week last week. 4 hrs of drive time each day so I didn’t get much done in the shop. I did bleed the brakes. I bled each corner several times so I’m pretty sure I got all the air out. There’s more pedal travel than I would like, but I think it will be ok. The BK brake calculator recommended the 7/8” single master, but I think a 1” would’ve gave a better pedal feel. I’m not changing it now though.
@Joe_U4 post about driveshafts got me thinking about trying to re-do my midship shafts to add a slip in them. I think I’ve found a combination of slip yoke and tube shaft I can make work.
I dug into the midship shaft re-do this morning. I think I can make it work. It’s going to require some custom fabri-cobbling, but that just so happens to be my specialty. I’m thinking the amount of slip needed should be minimal. You guys think 1/4” would be enough, or should I go with 1/2”?
I pulled one out this morning to measure. I disassembled it and the seals in the bearing were already blowing out and there’s a very noticeable rough spot just turning it by hand. I don’t think it’s due to a warped housing as the bearings went in very easy. I think it was caused by flex in the drivetrain and the solid mounted bearings. New bearings are on order.
I got the new version of the midship shafts welded up this morning. I used a spicer 3-3-398KX slip yoke, the shortest 1350 slip I could find. Combined that with a tube shaft I cut down from 2.5” of splines to 1.75” and cut down the tube end and sleeved it into a piece of 2.25” x .500” wall tubing. Then that was sleeved into 2.5” x .120” wall tubing to mate with the midship stub shaft. Not as pretty or as accurate as @Joe_U4 but she’ll still get the job done on prom night!
I mounted one of the tires last week trying to re-use the old o-rings in the Stazworks wheels. It leaked immediately. So I ordered new o-rings and bolts and hopefully can get the tires mounted later this week into next week.
When and where is the shakedown run on this unit?!
No idea. :laughing:
Was hoping for the 28th at the new East TN Adventures ride in Johnson City, TN since it’s 15 minutes from the house. But I was informed this weekend we were having a Thanksgiving dinner that day.
No idea. :laughing:
Been thinking about going myself but it kinda depends on how cold it's going to be. Heated seats only do so much to keep an old man warm :confused:
No idea. :laughing:
Sounds like you’re having a thanksgiving dinner at ETA.😂
Can’t wait to see this thing out and on the trail.
