shockerguy3559
Active Member
- Jan 4, 2008
- greensboro
And definetly dont wheel w/ the doors off or it'll twist in half...IMO, if you are into the larger body, then get an 80s Yota 4Runner, not truck.
That way you get everything in the Pro side of being Yota mention above, plus space for the family... and even better... you can remove the top for that more open/convertable feeling.
The 22r / 22re is a great lasting motor also, and have been known to last well over 200,000. The 4.0 is one hell of a motor too (C-Kee)........ I am still running a G-52 series Toyota Tranny and I have managed to break the output shaft in the rear 4.7 T-case (ALOT OF TQ). The Tranny held up great........ (the W-56 is the strong tranny or R-series is better) True the 4.0 in the C-Kee is strong and torquey. It's way stronger than the 2.4 in the Yota's.......... However, I know what I put mine through, and it holds up too it. Everything in it is stock except for the front axle shafts, the gear set in the rear case, and the adaptor to mate the 2 cases together. Toyota is some strong shit, and they perform well.......... The stock axle shafts in the front of a Toyota will hold and turn 38'' inch tires........ I have seen several people do it for along time. You will never turn 38's and beat on a C-Kee stock (Dana30/35) out of the box.......... like you can a stock geared/axled Toyota. I am not bashing Jeeps, but I have wheeled enough and seen enough....... Out of the Box...... Toyota has it. You can build a very, very capable yota for cheap too.
LOVE the fj80's.....to heavy in my eyes thoughget a fj80... solid platform... room for the family and you can also find one with lockers.
or 85 4runner... very cheap too build has the 22re
if u run 38's on stock fronts in a yota there will be lots of birf changing????correct?
cool, everytime im out i see them breaking i must have bad birf karma?Metalmangler (SHAWN) has only broken 1 birf in 5 years that one he broke was as "pull cable" in Mountain city.... He turned 39'' boggers like a crazy wild man
I turned 35'' boggers for alittle while on a WELDED front diff. with birf's and never broke one.
Cumminsdzl turned 36'' TSL like a hell raiser for awhile on birfs and never broke one with an aussie installed.
Cornbread (Darrel)turns 36'' TSL's with bead locks and steal rims and a welded front diff. and has broken one.
Most of the boys in Cali. run the hell out of birfs........
Do they break? Yep........ if you keep the steering straight when you hammer down............. your usually golden. Set them steering stops all of the way out and get some!
C-Kee is probably my favorite out of all Jeeps..... I like them. I guess I am just parcel to Yota. Stock yota stuff is easy to MOD and fairly cheap too.........
ps.... I like busting your nutz! LOL.......
What he said ^^^IMO, if you are into the larger body, then get an 80s Yota 4Runner, not truck.
Thanks man. I am trying to get used to it, after having a TJ for so long. I definately like the room inside.yea dylan you got a nice cherokee it did work a few weeks ago when i saw it
