My motor is done
NASH-TY-AMC
Charlotte
here is a picture of my amc 360 that is done finally
no pic. Have you seen the testing ground?
Might wanna put some belts on it. Has anyone used that type filter on the oil fill before? Mine is still stockish with the hose running to my breather.
You're not keeping the points dizzy are you? :eek: (unless it's being used as a 3500rpm "rev limiter"? :shaking: )
Can't see it hurting. Mines the OEM steel canister (w/ some filter media stuffed into it... when the original "media" turned to dust! :lol: ). His filter does have a "modern" look about it!
He might have the protronics in it like mine!
Mine has the media in it too. I kinda thought the vaccum from the carb would help pull gases from the crankcase like the PCV does.
I used that same breather on my 401 build, It worked pretty good
get rid of the petronics and swap a motorcraft dizzy, and do a Ford TFI upgrade on the thing, you will thank yourself later, an Chip might disagree
man that thing looks good,but the distributor is at the wrong end:flipoff2:
