http://www.dpccars.com/car-videos-08/07-29-08page-Mechanic-gets-crushed-under-car.htm
Disclaimer: I have no idea if it is real or not..
one thing that REALLY bothers me about this forum, is when I see pictures of stuff like this, or pictures of people using cinderblocks or something as jack stands...
Come on people, if you can afford the parts, afford the rig, and afford the tools, you CAN afford the safety of a real set of jackstands..
I have used wood blocks. If you lay them two or three beside each other, then two or three on top of them at a 90 degree angle changing direction with each layer, this can be safe. Just be sure it's not going to slide off this cribbing.the problem is they don't make jackstands tall enough for our applications, or at least the only ones I've seen are ridiculous high priced, but i usually go with wood blocks cause i have seen bricks and cinder blocks both fail firsthand![]()
the problem is they don't make jackstands tall enough for our applications, or at least the only ones I've seen are ridiculous high priced,![]()
Ok, for you engineer types -
If used PROPERLY, shouldn't cinderblocks be plenty strong? E.g., lay then with holes facing down, solid walls on the verticle, stacked in a triangle so thr weight is distributed across their length? Used on flat ground, of course.
They're used thsi way to hold the weight of all kinds of very heavy things.
Used a 4x4 chunk of wood post once, in a pinch - wasn't sure about it, so carefully let the weight down... and low and behold, it split right down the middle. Ended up finding a better solution....
A rail road tie is $20 tops.
Saw it in to quarters with a chain saw.
Place appropriate weight rated jack stands on rail road tie
Viola
No, they will not work. If you want to test it you need a crusher. Before the job I have now I tested a lot of concrete.
It would work in a lab but not in real life. In the lab they cap both sides to make the load equal across the top and bottom.
In real world they are set in concrete for the bottom and the top has a wood cap, most are filled where the wood will set on them and have bolts or studs set into them. The wood cap will also have more wood flat on top of it so as not to have a point load. The load will be across the wall. If you had a way to check the load under each stud and then between the studs the load on the cap would be the same.
What happens when you use it for a jack stand, the load is a point load and one part will fail, making the block fall apart. What will help is to place a piece of wood 2x10 under and on top of the block to spread the load out. Even more would be to fill the block and cap it with wood. Best would be to cap it with 1/2" steel and fill with concrete. But to move that and the cost and time to make it but only have something that is So SO for safety, is not worth the time.
Bottom line you could do some things to make it safer but its best to use jack stands.
Fine go for it.....i use blocks alot when i need to have the truck up high enough where jackstands wont reach or if im using all of them in the shop and on the pad and jsut dont have any free. i allways cap the top with a thick plank and am carefull.......yet to have ANY fail and thats proablly under 20 rigs . check the blocks and make sure there in good shape. Im sure people have had them fail and its not somthing i like doing but when it has to be done gota use what ya got. ill keep using them until i get my lift out there.![]()
