whitneyj
- Apr 30, 2008
- Mayville, WI
I've never heard of this done before, I'm also curious about the drivetrain setup. Are there any links to other builds of this nature?
You're saying a transmission will go between the motor and that transaxle? Just curious and a little confused about it
Rather not stress the budget, add weight, or complexity. Yes I fully realize light weight and low budget don't usually go together
Looks like I'm definitely doing rear engine, so that will be cool. Still lots of small things to ponder. Chase at East Coast Gear Supply was nice enough to loan me a used D30 carrier. Mainly wanted to compare that to the F23 unit. It uses the same carrier bearings so I was curious as to how similar they are dimensionally. Seems to be ~1" shorter. I need to check the spiders etc once I crack the transaxle open.
That wouldn't work if he locks the diff inside the transaxle.What if you put brakes on both outputs and used them like tractor brakes except front/rear? I would think that most of the time you would never need them, but you could modulate front dig rear dig. Kinda sleepy, may just be a stupid idea.
Does the direction the axle/driveshafts turn determine front or rear engine? Don't know why i even thought of that, but it would suck to build a badass buggy with 5 reverse gears and 1 forward.Looks like I'm definitely doing rear engine,
Doesn't matter. Just figure out which way it turns and orient the differentials accordingly. (upside down or not)Does the direction the axle/driveshafts turn determine front or rear engine? Don't know why i even thought of that, but it would suck to build a badass buggy with 5 reverse gears and 1 forward.
