happiness is a 1200 hp buggy
Are those those "Whistler" pipes I've heard about...
uhhh....f'n Saweet ride....![]()
ok, getting alot of head room questions. yeah its tight but there is more head room than you think. my head is level with the top of the seat. so i think i will be ok, but i appreciate the concern.
Are u going to inject nitrous directly through the turbo to spool them bc even variable vane turbos have to have enough pressure to spool also what kind of waste gate are u going to run I haven't saw a cummins waste gate go down to 5psi to actuate the vanes
I just saw where somebody said 1200HP so I was thinking the compression and cam had been changed to allow more boost. For sure a wild build. Subscribed
Will not touch 1200 the stock block will not hold it maybe 500 or around that realistically
pistons and rods.....So an LS1 block is only good to 500hp?
hrmph, learn something new everyday...
What is the weak link there?
