2002 2500HD - Solid Axle Tow Rig
Croatan_Kid
How's your hammer hangin'?
New Bern
I've got a few things I'll be working on today.
A little maintenance: rotating the tires, grease the front end, change a u joint, change the underhood fuel filter. Might even paint the front driveshaft since it'll be out anyway. Oh, and a drain/fill on the transfer case. Should probably check the gear oil in the rear end too.
I did order some parts. I'm real tired of the parking brake sucking ass and I ordered new shoes, hub seals, hardware kits, etc.
Also pretty tired of the power steering pump sucking ass. I ordered stuff to make sure I can steer no matter what's happening. I'll obviously post pics and details when all that gets here :D
Probably going to work on the trailer winch mount today as well.
Croatan_Kid
New Bern
Didn't bother with the front driveshaft today. The double cardan needs to be rebuilt, so that's a project for another day.
I rotated the tires, greased everything, checked the gear oil in the rear end, and then went to check the transfer case. I pulled the fill plug and got a geyser. Not sure what's up with that. The only way for that to happen would be a bad input shaft seal on the transfer case or the needle bearing in the input shaft is letting fluid leak around it. Maybe I overfilled the transmission? I don't know, but I'm going to check it again in a few weeks. I don't want to have to pull that big ass transfer case out again. The picture is after it has drained for a hot minute.
I did do some eyeballing and figuring on the best way to mount some of the new steering parts and how to route lines/hoses. I think it'll work out quite nicely.
I also changed the fuel filter under the hood. Very exciting :D
Here's random pictures I snagged. Honestly, all the front end stuff looks pretty good to have been under there for over 5 years and almost 100,000 miles.
Croatan_Kid
New Bern
My package of steering goodies showed up this afternoon while I was at work. The only thing I've got to get is some lines made. I didn't want to pay for their lines as they seemed kinda overpriced. I'll likely get some made locally.
This was just under 1000 dollars worth of stuff. I have definitely noticed the brakes not braking like they used to and the steering not steering that great. Especially backing my trailer, sitting still, etc. Usually works better soon after startup and I'm sure it has some wear and is losing pressure. I'll be adding a cooler as well. The 1500s got them. 2500s didn't. Makes no sense to me.
I guess that 345,000 mile, factory steering pump has about had it. It's a shame stuff won't last that many miles and/or 20 years...
I got 6 qts of that stuff to make sure I get a good flush and it covers the small added capacity of the cylinder, lines, and cooler.
Everything is Jenny and Shelby approved!
Croatan_Kid
New Bern
I'm gunna and it'll be fine. 99% street driven, tow rig.
I just want the wheels to move left and right whenever I tell them to. Mostly when sitting still and moving slow while maneuvering with my trailer behind it.
My other truck also has a tie rod clamp, albeit, not a single sheer setup. Not sure which is more "dog shit" to you.
Croatan_Kid
New Bern
I meant to post this earlier, but fell asleep on the couch after getting a belly full of corned beef, cabbage, and mashed potatoes. Washed that all down with a Guiness :D
Since it was likely the only kinda nice day of my weekend, I swapped out the power steering pump real quick. There's three bolts along the front and two on the back that hold it to the big aluminum engine brackets. Then, obviously, one pressure line and two returns. One from the hydroboost and one from the steering gear box. Of course, gotta swap the pulley over too. I did pull out the upper part of the fan shroud and pulled the fan out to give myself some more room and save some skin on my forearms, hands, and finger from all those sharp plastic edges.
Immediate night and day difference. It'd probably be even better if I had pulled the return line at the hydroboost and given it a good bleeding and flushed out all the old fluid to make way for the Swepco stuff.
The plan for tomorrow is to swing by my buddy's shop to add the power steering cooler, mount the assist ram, run up the road to CarQuest for some hydraulic lines, and then get everything nice and bled out/topped off. The brakes feel much nicer too.
I'm honestly surprised the stock pump still worked as decently as it did. I think the new pump also cured a bit of a whine I was hearing. I'm really glad I finally went ahead and did it. It's the little things, really!
Imagine the new pump. Looks like the stock one except it's silver and has a PSC sticker on it šŸ˜‚ They really do make some nice stuff. I'm over stock power steering pumps/boxes and crappy parts store reman units.
I'll pull the return line from the steering box to run to the cooler, then cooler back to the pump. The hydroboost only returns after you hit the brakes and, as such, isn't as constant as the return flow from the box. I noticed how warm (and how quickly) the pump reservoir gets on only a few mile drive. It blows my mind these didn't come with a power steering cooler, yet my half ton truck has one.
Anyway, tomorrow/later today should be promising (as well as slightly less messy) and I'm excited!
BNielsen
Member
Granite Quarry
Have you had good luck with PSC pumps? I'm looking at doing both PS pumps in my 96 K2500 and my 00 K3500 because they both make a little noise. I was looking at the TuffStuff pump, it's annoying trying to find a pump for hydroboost trucks.
Croatan_Kid
New Bern
Well...I literally just pust it on there yesterday. So far, so good. 275 bucks and it's assembled with a hydroboost reservoir.
I can steer sitting still now and the brakes feel much better. I'd call it a win.
That's still with mostly old fluid in it. I'm going to go flush out the old crap, add the cooler, and fill it with fresh Swepco fluid. It'll probably be even better.
Croatan_Kid
New Bern
I also wanted to do JUST the pump first, so I could compare the difference. I'm glad I did!
Croatan_Kid
New Bern
Since I remembered earlier when I checked the fluid. I DID have to bend the return line on the side inwards a little bit for clearance up against the ECM cover. Other than that, it was your standard drop-in replacement. Well worth the money.
Bebop
TN
Single sheer sucks.
Croatan_Kid
New Bern
Single sheer sucks.
If it were to ever break, I'll weld some tabs on it. The worst it will likely see is turning the tires on pavement while sitting still.
Croatan_Kid
New Bern
I considered that and got it covered. I just hope I don't have to take the bolt out for any reason šŸ˜… Actually...making it a stud would work better than my initial idea.
Croatan_Kid
New Bern
Finally found some motivation earlier today. I got out there and put the power steering cooler on and bled everything out. It was pretty simple, but I'm really tired of making a mess with power steering fluid!
Some ā…œ hose, a couple of fuel injection style hose clamps, 3 zip ties, and the cooler with the mounting accouterments.
Didn't really have room to lay it over horizontal and this was the easiest way to do it. It bled itself out quite easily and I have a very firm brake pedal. Just have to mount the ram, which I don't really need, but I already have it...
Not going to lie, that ram mount is kinda sweet. Especially for something off the shelf. Not exactly ideal, but it was pretty inexpensive and fits in that somewhat crowded area. I dig it. It'll probably get sanded and painted black at some point.
