Just curious, is there a reason to swap the engine/trans other than you just know the ones from your old truck?
With all you are planning to swap, I almost feel like it might be easier to swap the cab vs everything else.
I wondered if that might be the case. Good luck with the rebuild. It seems like a daunting task to me, but I have no doubt you can knock it out.To add to what I said earlier...
Yes. I've been the care taker of the engine in my old truck for 8 years. I upgraded the oil cooler, exhaust manifolds, up pipes, turbo, harmonic balancer, water pump...stuff like that.
I built the transmission in August of 2022. It'll hold all the power I'll ever make and was kinda spendy, just for parts.
The transfer case, I also built. The driveshafts go with that as they're both fixed yokes now.
I could swap everything except the motor, but at that point...it'd be easier to swap all the whole motor vs the individual parts. Having the motor out gives me access to cover the firewall and transmission tunnel with a nice, foil backed heat deflection and sound deadener material as well.
Chassis twisted in the crash ?
Set the new body on the old Chassie and be on the road in a couple days.Nah, it's fine.
Ford had it right all along!Set the new body on the old Chassie and be on the road in a couple days.
Thanks i needed a good laugh today.Ford had it right all along!![]()
This brings one question to mind though. If it's off the contact patch, why did it fracture? Deflection from over power when it broke the axle and locker?Deburr it and button it up. I wouldn't sweat that in the slightest. It's way off the contact patch.
A large chunk of the broken *edit* locker wedged in there, likely in the middle of the tooth. The middle of the tooth is strong AF whereas the inner portion is the weakest. It's simple physics that if the tooth had to break somewhere, the inside edge is where it would have.This brings one question to mind though. If it's off the contact patch, why did it fracture? Deflection from over power when it broke the axle and locker?
Dmax drag truck out of your S10????
We've been eyeing the duraburb conversions for a while, they sell for a pretty penny too usually. I'd definitely tune in to watch you build that. Good luck!Nope! Way better than that. Duraburb! Minimal investment and should be maximum profit...depending on who wants it when it's done.
I've got an entire drivetrain, cooling stack, front suspension, rear axle, driveshafts, TCCM, transfer case switch, shift cable, a FASS lift pump, fuel tank sump, engine wiring, ECM, TCM, exhaust, frame side motor mounts...literally everything I'll need. The only thing I'd really need to make/modify/buy would be the fuel filler neck.
Of course, I'll have to spend a little bit on fluids/oils, probably some seals/gaskets, and a few miscellaneous things here and there that will get replaced. I figure I might as well swap on an HD hood and grille whike I'm at it. I'll probably put the Ranch Hand from my new truck on it too. Maybe tires/wheels. I don't figure I'll actually spend more than 8 grand and could most likely double that, or a little more, from selling it.
Of course, I'd have to drive it for a little while to make sure it's good to go
The plan is to have a really clean, quality swap with some good upgrades sprinkled in that also looks factory. I'd go ahead and freshen up the suspension, steering, brakes, lighting, do some sound deadening, replace the body mounts, maybe upgrade the trailer hitch, and add some airbags under the rear. It should turn out really nice!
When all that happens, I'll just have to do another build thread!
