mcutler
- Apr 17, 2010
- mt.airy nc
Yes, looking slick buddy.
Matt
Matt
What did you end up using? Progress is looking good.
Sub’d
I’d say this build is in excellent hands.
Matt, all your thought process really pans out. For having it two days, you really have got a lot done. much figured out, so with plans in head and on paper, I figure it's gonna happen at a much faster pace than it would for most. I will siit back and drool
And like Paul said, we do miss you both out on the trails!
Another Cutler creation going on. Will be watching the magic unfold. Awesome work as always.
Thanks. I really love welding period. But tig is super satisfying when you get it right, and so much cleaner than mig. (I still love mig too). Tig doesn't take that much longer for me, because I've been prepping the same way for mig welds for some time.I'm really excited to see you start using tig more on your builds. Ive been working on my skills for about 2 years now and I am curious to hear what different settings, etc are working for you?
For tig, I have the blue machine for tig welding for dummies, lol. Diversion 160-65, I forget... I typically set the heat about 20% higher than the dial calls for, and modulate the pedal as needed. For #8 ceramic gas saver cups about 10-15 cfm, for the furick fupa 12, about 25-30cfm.
I'll upgrade to a more appropriate machine later, but truthfully, for the thicknesses I work on, and pretty much any automotive application, this machine is capable of everything I need. Especially on steel, I would like to be able to fine tune a bit more on aluminum.
Sent from my SM-G925R4 using Tapatalk
I feel the same way about welding and completely understand the thing about tig being satisfying. Do you ever have any trouble fitting a big cup in tight tube joints? I currently use a #8 gas lens for every thing.
Good info Matt, the Fupa also lights up the work area in a unique way. To off set some cost the monster gas lenses in ceramic will allow the same amount of stick out. The Furick web sight does a very good job explaining its draw backs. They shine on very atmosphere, heat sensitive parts and thin applications. The shield gas flows out and really blankets the component. I have a small theory in my head that because of the diffused gas is so slowed down by the cup much less contaminants can be pulled into the gas field through a siphon effect.....which most find obvious. My part is this blanket also is so slow moving at very small amperage settings you get absolutely no cooling effect from the introduced flow. It seems really insignificant but every setting I use; and my students have observed, is much less then with a standard cup or collet body. For the alloys it is designed for this is premium. Cause everybody wants that color and as small of a HAZ as possible.That's where the mfurick fupa pyrex cups shine. You can stick the tungsten out an inch or more to get in those deep tube nodes, and still keep sufficient gas coverage. They cost more, and use twice the argon, but quality of finished product in those extreme circumstances is tits.
I can't tell a huge difference between the fupa and a #8 gas on regular bench welding lap, butt, or filets. But around tube nodes, you can't beat em.
He has some new ceramic cups out now (along with a few other manufacturers, but he's a local guy so I buy from him, mooresville) that are big mouth with the good diffusers, that are more durable than the pyrex. I intend to grab some soon.
You don't need a gas lens on aluminum. A straight #5,6,7 is more than sufficient, and saves some gas.
Andrew, you would really enjoy sitting down and talking shop with Michael Furick. He reminded me of you, during that tig seminar this summer. Dude is a student and a master of the process, at the same time. He has really done the research and tested the applications for motorsports.Good info Matt, the Fupa also lights up the work area in a unique way. To off set some cost the monster gas lenses in ceramic will allow the same amount of stick out. The Furick web sight does a very good job explaining its draw backs. They shine on very atmosphere, heat sensitive parts and thin applications. The shield gas flows out and really blankets the component. I have a small theory in my head that because of the diffused gas is so slowed down by the cup much less contaminants can be pulled into the gas field through a siphon effect.....which most find obvious. My part is this blanket also is so slow moving at very small amperage settings you get absolutely no cooling effect from the introduced flow. It seems really insignificant but every setting I use; and my students have observed, is much less then with a standard cup or collet body. For the alloys it is designed for this is premium. Cause everybody wants that color and as small of a HAZ as possible.
