ckruzer
Infidel
- Jul 2, 2015
- asheville nc
Damn. Some pretty convincing data for Gas. Hmmm
Until the motor lets go...or the turbos both crap out...or any of the coolant system issues that seem to plague them. I'd honestly rather have a 6.0. At least there's a little bit of room under the hood to work on those.
Hopefully that one is deleted and tuned.
That's good! It should last atleast 35,000! [emoji23]Deleted studded cammed, all aluminum radiator, upgraded pistons, new turbos....... buddy built the motor not to long ago
Since its been brought up, now I'll explain my love- hate with the 6.4...Deleted studded cammed, all aluminum radiator, upgraded pistons, new turbos....... buddy built the motor not to long ago
When I built my 6.4 initially (08 f450, 4wd, 5r110, 4.30 gearing) I did everything that should have been done for it to be reliable. I bought the truck with a bad motor and no bed. I spent about 8g's building on a tight, in spec, 70k mile bottom end.That's good! It should last atleast 35,000! [emoji23]
Sent from my SM-G955U using Tapatalk
I literally cannot get them out of the shop once they come in. The list of needs is always expansive, once tear down begins the list always gets longer, once reassembled something else always happens and it expands again.Since its been brought up, now I'll explain my love- hate with the 6.4...When I built my 6.4 initially (08 f450, 4wd, 5r110, 4.30 gearing) I did everything that should have been done for it to be reliable. I bought the truck with a bad motor and no bed. I spent about 8g's building on a tight, in spec, 70k mile bottom end.
Items done:
-New turbos
-Rudy's Hd up pipes (that still cracked)
100% new fuel system from a relined tank to hpfp and all new lines from tank to injector
-resurfaced the log manifolds
-deleted egr, down pipe and filter
- heads resurfaced and fluxed
- new rocker arms, lifters, rods
-arp head studs
-complete ford engine gasket kit
- stainless cold air charge kit
- new cooling system including radiator, upgraded hoses and new tstats
-new oil cooler and fuel cooler
- stage 3 intake and ccv mod
- new water pump and front engine cover
-h&s tuner, ran on 70hp tow tune always, never hot rodded
It went 50k miles and then blew two piston, and got into cylinder walls.
Sooo... down 6 weeks (bought the v10 the first weekend)
Repaired bottom end to the tune of 6g. Including machine work to bore .030 to clean up cylinder walls.
- new coated de-lipped international (mahle) positions .030
- nothing on the top end needed any work (as it shouldn't with only 50k miles...)
- All new bottom end bearings
-new water pump/tstats again just for piece of mind
20k miles later and cavitation has eaten through the front cover and put water in the crank case. (no evidence of wear on 50k mi cover upon bottom end rebuild).
I drive it home 2 hours after changing the oil in a truck stop parking lot. Put a new $1000 front engine cover (single pin hole in cover) on over the weekend. Run 3 oil changes through the block before I put it on the asphalt again. On following Monday I drove 100 miles, and now have a knock in the top end....smh.
Have yet to attempt to diagnose (been 4-5 months- the manche was clogging up the shop...) Still debating whether to sell as is, repair and sell, or 5.9 crd or p- pump swap. The remainder of the truck has 270k miles on it and is as tight as any new truck I've ever owned, that's why I'm having a hard time parting with it... and it's a badass looking truck...
I absolutely love the power and performance of the 6.4 when its good (and it's my favorite front clip on a ford truck) .... It sucks ass when its not...
I hope you have continued success with yours.
.... if anyone is interested in this truck, feel free to give me a call...
Items done:
-New turbos
-arp head studs
Agreed.I like the way that truck looks and if I wasn’t trying to build my jeep I’d try to figure out a way to own it.
I know the 6.4 can problematic but like any other problematic trucks there are really good one and really really bad ones. Forums are full of the really bad ones. Most people don’t complain about how great their truck is running, knock on wood I haven’t had any problems out of the truck yet, not saying it can’t happen.
But I’m also a firm believer in people that have continued problems with a truck fall into a couple groups
-take on something over their level of knowledge and screw something up
- use subpar products trying to save a buck
- or they abuse the truck
Not saying that’s the case with your truck but that’s what I see a lot when I see people saying their truck keeps blowing head gaskets or whatever it is
Agreed.
Rest assured, money was spent on the right parts for this truck, and anything else I have built in last 15 years. I did all the top end work, and a reputable friend/ diesel mechanic did the bottom. I'm also very good at maintenance.
If this thread had started at 45k miles after building the top end, you would here nothing but praise about it. Spent zero dollars in two years on this truck.
I would honestly like to fix this truck, but frankly I have a load of projects that need my attention in the next couple months. We shall see...
Maybe I was lucky, but my 6.4 was problem free from 300k to 336k, other than one deteriorated body mount. It was driven hard, but taken care of. DPF deleted and pretty hot tune. I even let @Ron borrow it, when he needed a real truck instead of a Toyota, and it made it back in one piece. That squeaking body mount drove him crazy though.
That's the guy who bought my truck to a tee! He traded a perfectly good LLY Duramax for a "built and tuned" 400hp Evo, then spent a bunch of money fixing it and getting it tuned right, then turned around and sold it within a week. Recently he bought a 6.0 Ford, paid someone to rebuild the entire frontend, then spent about $5k having it bulletproofed and deleted. While it was in the shop for that, he borrowed my 6.4 for a week, and loved the power and how quiet it was. The week after it came out of the shop, he Sold 6.0 for about what he paid for it, and bought mine.That'd hurt ny feelings...what kills me is I see a bunch of trucks that get new injectors, a built transmission, turbo, and built motor...then they sell them. Wtf? At that point, you better keep it forever!
You mind giving me this guys info? I’ve got a bunch of crap to sell that he can spend money to fix.That's the guy who bought my truck to a tee! He traded a perfectly good LLY Duramax for a "built and tuned" 400hp Evo, then spent a bunch of money fixing it and getting it tuned right, then turned around and sold it within a week. Recently he bought a 6.0 Ford, paid someone to rebuild the entire frontend, then spent about $5k having it bulletproofed and deleted. While it was in the shop for that, he borrowed my 6.4 for a week, and loved the power and how quiet it was. The week after it came out of the shop, he Sold 6.0 for about what he paid for it, and bought mine.
Ha! No way! He actually bought an Audi S4 from me the day after he sold that Evo. So he's my best customer! And also one of my best friends, who knows that when he buys something from me, he's getting a tried and true, sorted out vehicle that is not full of random problems, and if anything does come up, I'll be the one offering up my labor and lift to help him fix it.You mind giving me this guys info? I’ve got a bunch of crap to sell that he can spend money to fix.
The only issues I've heard about with 8.1 oiling is just that they have a consumption rate...usually about a quart between oil changes.
This is a legit question. Wouldn't the larger bore and stroke be better for longevity even though the LS2 makes close to the same power? Also, at 11:1, the LS2 would need 93 octane pump gas instead of some cheap old 87, wouldn't it? Not to mention the RPM power range difference between the two...but surely you'd opt for an L92 6.0 for a tow rig instead of an LS2.
Gay Man’s Cadillac
