1-tonmudder
Doin my part to stir the pot.
- Apr 17, 2005
- Greeneville TN
might be but I was thinking it was the other way around.Huh? Sure you're not thinking about the powder metal rods in the late 01's and up?
I was leaving golden mountain fully loaded and hit that climb on 40 with the cruise at 70 when the temp went from 215 to 250 in less than a second. Limped home by stopping every 100 miles to add a gallon of water(thank GOD for @Jason W. )
After that I got decked, ARP gaskets, ARP studs and never use the cruise unless I'm rolling on flat ground. (lesson learned the hard way)
4" exhaust (WITH MUFFLER!! Sounds like ASS straight piped)
EGR delete with sinister up-pipe
65+ HP towing tune (SCT)
SOME kind of monitor to constantly watch EGT, EOT, ECT
And most importantly, DO NOT leave the cruise control on when climbing with +10K load.
So, what actually happened??
Stretched the TTY's, lifted a head/smoked the headgasket?
However, I bought the fawker to be able to USE the Cruise in OD while pulling a load!
Yup
Once I replace my radiator I will be able to do this. That's the last item on the list I have to replace.
According to my research (intense lurking over keyboard warriors on different forums) the mushy moto didnt really give any better "performance" and the fanboys were all tim Taylor grunting over "stock"FYI if you do some looking you can get a new all-aluminum radiator from Mishimoto for about $350.
I've found Ford for $350. They ain't cheap
Bulletproof has the all aluminum mushy motors for nearly $500
Mishimoto Ford 6.0L Powerstroke Aluminum Radiator, 2003-2007 | eBayYea search eBay. It won't be the first thing that comes up, but you can get a genuine Mishimoto for around 300-350 shipped. I have bought two. I wouldn't pay the $500+ price for one.
03-04 had different connections than 05-07
Can't see how they can say fits 03-07
Also, not compatible with manual trans (scroll down to see warnings)
Why would you even need to? It's not like coolant circulates through the transmission, or is it a trans that has a water cooler on it? I didn't look it and not familiar with the particular application. But even if it is a water cooler on the trans, I don't see why you couldn't source plugs & just plug the connections.I'm wondering if you can just plug the auto trans cooler bungs
It is but I was wondering if the connections were for coolant or trans fluid.I'm no R Kelly, so maybe I'm reading it wrong, but is that not the same thing I said?!?
(Not being an ass...this hour loss + lack of sufficient coffee has me questioning logic)
factory oil cooler and install an oil cooler in front of the radiator
The BPD version Or something else?
I then made my own setup with a Cummins oil filter base (I had 40 new Cummins filters so figured I would make use of them), a huge cooler I had here, and some push-lok hose and fittings. The only downside is it is a little more time consuming to do an oil change. I have to drain the oil pan, the filter, and the cooler. Capacity is about 6 gallons now though. The cooler I used is larger than the one BPD uses, but mine was free haha. Don't take free that it is cheap, it's military surplus so it was likely VERY expensive when all of you guys helped pay for it the first time.
I'd seen that they offered just the block-off plate, but... I was a bit intimidated by the their disclaimer language and the large numbers of "Optional" ports... Care to share your plumbing diagram (ports used, ports plugged) with that plate?
How big a cooler are you talking? Specs?
Where'd you mount it exactly?
4" MBRP, LiveWire TS+ w/ EGT & backup camera(plus, LED backup & work lights, seat covers, mats, and a host of other non-drivetrain parts)
Short of a stuck ds brake caliper,the annoying door locks that don't unlock the rear doors when you put it in park and the seat belt beeper its been good so far.Changed the oil to Mobil 1 full syn,ford filter and fuel additive every other fill up.We were on our way to Pa in heavy blowing rain and the air filter light came on.Stopped and pressed the button on the filter minder and got about another 40 miles up the road before it went off.Finally stopped at the nearest Auto zone and bought a new filter even though the one in it was suppose to be new. Pulled it out and sure enuf it was new but it was a little wet on the grill end of the filter.I guess 6 hours of hard blowing rain and interstate speeds finally got to it.Went on to Pa w no issues.@1-tonmudder Wondered how your experience with your new rig has been going?
While only about 300 miles on the 4" MBRP is not much, I believe the MPGs are gonna go up!
Previously, it'd do the first 50 miles before dropping off FULL, and a 1/4 tank (gauge) per 100 miles, with 400 miles until the light came on at <1/8th... +/- 13MPGs
I did 275 miles a week ago Saturday to assist a bud retrieve a 40' 5th-wheel camper off the side of a mountain in Cana, VA and haul it back to SML... VERY hilly & stayed in it hard several times so @Tater could hear the exhaust
Now, a little over 350 miles on this tank and it's still well north of 1/2 tank... time will tell, but can't wait to hand cipher.
Also, LiveWire TS+ is on! Running the canned 50HP Tow tune makes a HUGE seat of the pants difference... HUGE!
May drop the 100HP "street" tune on for giggles, but am thoroughly pleased with just the above.
No.I've already put about 12k on it since Jan.Over 1100 just this past weekend.I don't think any grass will grow under it while you own it,
