Well it has certainly been a while since I have done anything to my jeep and or spent money on it. With my tax money from the previous year I ordered a rear spartan locker after hearing about their growing reputation. I was not concerned with the install since all I knew was that I was basically just replacing the spider gears and closing it back up. So I did a little documentation as I progressed through the task!
Popin that cover and pull the bolt holding in the cross pin.
Get them tires off to pull the axles
Shafts, C-pins, and Center Pin gone. Start tearing it down!
What Spartan Sends You
And then the assembly begins! I am only used to assembling the Aussie that I have in my d30 and this was much more different. It is hard to explain writing down here but this is my image aid. The wire pins hold the pins into place since they are spring loaded from the inside. Pull them when it is assembled inside the carrier.
The instructions that spartan provided were pretty original and non specific to the chrysler 8.25. The instructions helped step by step but failed to mention anything about when or where to put int the c clip. It took about an hour of trial and error until I figured out how to wiggle in the c clips and get them to stay in their place.
When it is all said and done!
I got 85w 140 lucas oil to put in after the install, the heaviest oil at autozone, and I guess it seems pretty quiet when going around turns and corners. It was popping really bad during the first couple of miles but is now gone after it "settled in and got comfortable." Ready to see some results on the trail this summer.
