And so it begins....
Started the night with this....
Went to this...
Mounted with rubber feet on a s10 computer holder
Got the mil wired up
Then the fun part... hooked up the scanner to confirm I did a few things right. Now waiting on my ecm to get back from Jims Performance. We also got the boost valve in the tranny swapped out.
It will be running soon, waiting on the ecm to get back. I still have to put the crank postion senore on and a few vacum lines and the fuel lines and tranny cooler lines. The list is getting shorter...
Got some stuff done tonight. Got the fuel lines run, the tranny cooler lines started and 2 more gauges hooked up and the hood back one. The fuel lines are run inside fire reatardant sleeves. I replaced the hood tie soens with some nice alum washers and bolt, needed because it bolts through the double layer on the hood.
That is a really clean wiring job, this thing looks like a race car.
That e2000 pump is going to die a quick death being fed like that though...
Got more done today. Got intake mounted with the intake air sensor, oil filter lines redone, throtalle cable and tv cables done. Also had a few buddies came over and they knocked out some stuff like changed the shock bolts, track var bolts, tightened up the king pins adjuster, knuckle studs, leaf spring bolts..... list is getting shorter.
Pics
With some help from chris griggs we got her to fire up tonight!!! I have lost one of the egr tubes so it has a huge vacum leak so hopefully thats the idle issue we where having. Also found 4 different leaks so hopefully that will be it for those. Powder coat came back and wow it looks good.
Damn man that thing is fawkkkkking wicked... Oh an your wiring work if fantastic ill let ya do that to my 350 for free..lol btw didnt get that hat wasnt sure if ya sent it or if someone seen the coolness of it and jacked it from the mail haha got any walkaround vids of this beast yet???
More. The obd cover is from a ford f150 if anyone else wants one, they clip on the wire also so its harder to loose
Yes the intake is in the cab, its stock form. It went to URE today for a shake down run. Couple of small issues. I busted a ps pump due the upper link hitting the tube coming out of it, easy fix. fan 180* all day, hit 195* on a low range beatdown on a speed run up Daniel....
The final list to get done this week
Swap out front shocks
Make limit straps
replace ps pump
make overflow for ps resi
mount 3 fire exhuasters
mount saftey hammer
bolt up skid plate
mount other number plate
mount horn controler
mount intercom and wire
mount radio and wire
mount Mil light
tabs for mounting tool bag
mount first aid kit
spool winch line
wire in second battery
mount roof panels
ck fluids
not alot really for a week out on a race rig.....
