I got tired of looking at my temporary shackle relocation on the rear leaf springs. They hung so low that I was afraid they were going to bend the springs if I backed into a rock, and the springs were just too wore out. So I decided to buy some new springs and make it better. Ideally I needed a 2-4" Grand Wagoneer front lift spring. Unfortunately it doesn't seem like they make the Rancho 44044 springs anymore, and the next alternatives were going to be $500+ for the pair. Being the cheap person I am, I went with the Pro comp 13311 (4" lift springs for 52" Chevy Square body) and planed to run SUA. I figured at $129 a piece I would give them a shot, and they will be making aftermarket square body parts till the end of time.
To keep the wheel base the same, I welded new hanger mounts 1.5" forward from the original location. The original hangers were beat and needed replacing anyways. I mocked up the new 52" springs and quickly realized that the stock rear shackle mount was not going to work.
The rear shackle mount needed to move back around 2" (guessing for the most part). This lead me to just chopping the end of the frame and crossmember. Before cutting out the rear crossmember and frame, I made a new 1.75" tube crossmember just forward of where the new shackle mount would be.
Due to the fact that the frame chop went right through the original shackle mount, I needed to plate and box-in the rear frame section.
Finally I could weld on the "new" shackle mounts and test everything out. I took apart the leaf pack so I could check the angle and clearance at bump and my 2" guess was looking pretty good. It feels good to get rid of the slight Carolina squat and have the shackle up higher and more out of the way.
I took everything back apart for final welding. Now I just need to build a simple rear tube bumper, and test it out. The first road test did have a slight vibration at lower speeds (15-20 mph), so I'll need to track that down.
