Finally
Well I finshed the front 3 link today.
First I had to cut off the factory LCA brackets
I had to clearance the Factory UCA bracket for the new uppper. Would have just hit it on the way to full bump. You can see how much I had to remove in the upper right hand corner, Can't clear too much due to it being the gusset for the engine mount.
I did the same on the passenger side and It was done.
I test drove it down the road and it did very well, the ride compared to the short arms is next to none. Besides the fact I have no more wobble (Other than tires be out of balance) it tracks well and sees to handle much better. I have the upper set in the middle of the frame bracket, So I have some adjustment in it. It will take some time to determine what works best. I will get some flex shots next weekend at the charity run, Can't wait and can't believe I got it done. Now I just need to 4 link the rear, but it will be a while (Gathering parts)
Thanks to everyone that helped me make it happen
