RatLabGuy
- May 18, 2005
- Churchville, MD
FIFYThat would never work. It's not MEGA enough.
Amazing. I just came in from laying on top of my buggy for the last hour looking at the stars. I saw one shooting star and several satellites. It was so peaceful and quiet I almost fell asleep lolMan I bet thats an amazing night sky out there.
Wait - isn’t the stock radiator a copper unit?I will wait on the trans cooler then. I'll see how it does from Arizona to Utah and then decide if I need the cooler. I ordered an all aluminum 3 row radiator that had good reviews by a few Kodiak owners. After reading about DexCool jelly and stuff it makes sense why mine varies greatly and leaks intermittently. I'm going to flush the system with water several times, drive it around and flush again. I'll find a place to flush it again in Utah before leaving. I'll keep those chemicals in mind.
The truck feels a little sluggish here until I make a little boost, even without the camper behind it today. I also noticed when my air compressor kicks on it seems to run longer, yet I have no leaks. Best I can figure is it's the higher elevation here with thinner air?
Get that logical nonsense outta here!Wait - isn’t the stock radiator a copper unit?
Why would you take a vehicle that’s having cooling problems and replace a copper radiator with an aluminum one ?
This isn’t a race car and you aren’t concerns with shaving pounds. Going to an inferior conductor is the last thing I’d want to do.
Elevation definitely makes a big difference! You can read barometric pressure on the Edge monitor. I don't notice any power loss running up to Canton or Asheville, but were talking what...2000-ish feet above sea level, maybe?
4000+ will definitely make them wheeze some!
Ah. If stock is plastic/aluminum then no loss there. I thought all those trucks used a proper radiator.Im currently a little over 7,000 feet here so that makes sense.
My understanding was it is plastic tanks crimped to aluminum core. I was more concerned with getting away from the plastic tanks and thought aluminum would dissipate more heat as an added bonus.
I have not seen a copper brass radiator in years. Every factory radiator I've seen is aluminum with plastic tanks. I'm pretty sure our Freightliners have all aluminum. I could be wrong.Ah. If stock is plastic/aluminum then no loss there. I thought all those trucks used a proper radiator.
See also: witch's tittyI have not seen a copper bras ... in years.
Fixed! My wireless keyboard likes to skip spaces and letters.See also: witch's titty
