jeepinmatt
..l.
- Mar 24, 2005
- Stanley, NC
I think at this point, we are waaaay beyond the finer details...
I'm right outside Cortez, CO.Where are you? A friend is doing a gig as a campground host at Cottonwood Campground. Travis Mattson
Ah about 5 hours SE of Travis. He's being a campground host now. IF you wanted a no nonsense view of it he'd be a good one to ask.I'm right outside Cortez, CO.
It's beautiful here. We hiked past the cliff cities and to some Petroglyphs on Thursday. We didn't plan take that hike, it just kinda happened since we were there. It was not a good decision as we were not prepared. We had one battle of water between us and that was it. We also hadn't ate much of a breakfast. We found ourselves all pretty bad off about 2/3 of the way thru. Turns out we'd totally overlooked the signs warning about how strenuous the trail is. However, we were one of many groups of folks who'd made the same mistake.We were there and stayed at the Mesa Verde KOA. It was a bit pricey but we liked it. Nice and clean and organized but the pool was out of order.
I'm glad we did it, it was the most beautiful hike of my life. But man what a recipe for feeling awful. Lesson learned on that!
Have you hooked a scan tool to it and watched live data when it shits out?I do also have this random issue that has been worse as of late and I really need to figure it out. My buggy will just lose all throttle, out of no where. It used to only be when I was beating on it and really opening it open across the sand or an open trail/road. But now sometimes it does it at start up, or just randomly cruising. It just stops and goes to idle, the throttle does nothing. I have to cut it off, kill the master switch and restart. sometimes a coupe tries, and the throttle will come back. I've put dielectric grease at the pedal plug, and the throttle body plug. This is going to leave me in a bad situation, like on a ledge or technical climb at some point and it would be very expensive to switch it out for drive be cable. Any suggestions?
My jeep is doing the same, and has had a combination of 3 throttle/pedal position sensor codes at random times. It's only doing it at startup and my Bluedriver can clear codes while running. So, I fire it up, clear codes, and drive.I do also have this random issue that has been worse as of late and I really need to figure it out. My buggy will just lose all throttle, out of no where. It used to only be when I was beating on it and really opening it open across the sand or an open trail/road. But now sometimes it does it at start up, or just randomly cruising. It just stops and goes to idle, the throttle does nothing. I have to cut it off, kill the master switch and restart. sometimes a coupe tries, and the throttle will come back. I've put dielectric grease at the pedal plug, and the throttle body plug. This is going to leave me in a bad situation, like on a ledge or technical climb at some point and it would be very expensive to switch it out for drive be cable. Any suggestions?
I know some of you hoped for it…. Yesterday was your day then.
YT commenters can be real jerks.Really? Why the hell would someone wish this to happen?
Well we all knew this day could come. It was always a risk, and I know some of you hoped for it…. Yesterday was your day then.
