Cl find of the day
1994 Toyota Previa, True 4WD HI/LOW, Lifted, Mini Camper Van
1994 Toyota Previa, True 4WD HI/LOW, Lifted, Mini Camper Van - $6000 (Black Hawk, CO)
Please ask questions and for more specific pics.
I bought this '94 AWD Automatic Previa in cherry condition with 140K miles for $4500 in 2013. I then bought a 1992 with 180K miles still running like a top for $1300 to get its manual transmission, clutch, driveshafts etc for the conversion (and backup motor) and found an 80's Toyota van 4WD high low transfer case with shifter and linkage to convert this into a true 4WD vehicle. In all I have around $8000 into this van plus my labor.
If you are curious or serious enough, please create an account and login to see some of my conversion work documented here (This link only works if you are registered and logged in: ToyotaVanTech Forums
Features:
- 4WD with high/low range
- 5 speed manual transmission
...<<snip>>
this is cool
Picked this up off Craigslist yesterday. 3 speed Saginaw with Borg Warner overdrive. Water poured out of the solenoid when I went to check it out, but the price was right so I figured I'd give it a shot. Cracked it open and the gears in the case and the overdrive gears look excellent. Took apart the solenoid today and cleaned up the contacts and got it working too. Score!
I would question if that K5 has a cummins, or if it just has a cummins sticker until I see underhood pictures.
What is the life expectancy of a Dana 44 ball joint with a 1,200 lbs of Cummins engine bouncing on it?
not for nothing....but for $70k I would expect AC and the builder not to rhino line over that dent in the leading edge of the hood.....
I don't like rhino liner on anything but the inside of a truck bed.You can cover up too much shitty work w it.
